Converting dinette to bed Q
Discussion in 'A-Frame PopUps' started by OneTruth, Aug 31, 2019.
  1. OneTruth
    OneTruth Member
    31
    Aug 18, 2019
    As I explore my “new” pre-owned 2015 Aliner Ranger 12, I’m puzzled why there are 4 wood slat boards in addition to the tabletop to form the bed surface. Is there a “proper” way convert the dinette area into a bed?
  2. jadmt
    jadmt Member
    62
    19
    Mar 26, 2019
    You don’t use the table top. Just use the slats equally spaced.
    OneTruth likes this.
  3. Sotovoce
    Sotovoce Active Member
    219
    96
    Jun 27, 2015
    Georgia
    Ditto what jadmt said.
  4. WrkrBee
    WrkrBee Well-Known Member
    3,580
    1,532
    I sent an email to NW addressing the useless owner's manual when it came to the "VersaDine" setup.
    Our 2018 Aliner Scout dinette bed was supplied with 4 boards , 6" wide, so your total support is 24" wide. The hole to cover is 38" deep, so there are 14" of unsupported cushions. The email I got from Aliner said the dinette table is to be "stored" on the floor and not used for the bed setup. The owner's manual was no help showing the "VersaDine" setup.
    I ended up cutting 2 more pieces of 1x6 to fill in the gaps, not covered by Aliner. Last time I checked, unsupported foam doesn't have a lot of structural integrity.
    The table top is useless, unless it has been redesigned which I doubt, since it has 1" plastic band stuck to 1/2" wood. It could not carry any weight, since it is for looks only. I also, cut 1/2" thick support pieces for the dinette table top plastic trim.
    Econ and neighbormike like this.
  5. Anthony Hitchings
    1,031
    452
    Mar 2, 2019
    that's odd, our 2003 Scout's dinette table was also the dinette bed base - and sturdy (=heavy)
  6. Merlin14
    Merlin14 Active Member
    539
    59
    Aug 30, 2014
    When we looked at our new to us 2014 Classic, I knew the slats had to go. Hard to use them, easy to scrape knuckles, and other reasons.
    It's all particle board anyway and I want the storage space the slats take. Remove the table, store it in a slot in front of the slats, store the pedestal pole. Install the slats. You may need a nap after that.
    Here's what I did: I cut down a 1x2 hardwood board to fit and predrilled 12 holes 1-1/4 in deep through back end of table (square end).
    Into these holes were HAND DRIVE ONLY 1-3/4 wood screws. If I re-did the screws, I'd run the screws in 1/3 way and remove to get scrap removed from hole, then repeat for 2/3 way then HAND DRIVE home. Slats are now in attic, where adhesive wrap will loosen in the years ahead.
    Then I cut a hardwood board approx 12"x 24" to fit closely but not tightly to allow for expansion and install/remove.
    This now fills up the area completely, or the hardwood can be left out for slightly more floor space. (The hardwood piece is not in pic below.)
    Next thing is get rid of the pedestal mount and base on the table and floor. Not sure yet but the table legs below will NOT work. Too long.
    You guys got any ideas? I want the table, but not the way of mounting.
    Our first trip was this past weekend and temps were at 100 degrees. All systems worked fine, but refrigerator can not operate well at 100.
    Econ likes this.
  7. StlAnnie
    StlAnnie New Member
    Jan 18, 2018
    I simply don’t use that table top. Instead, I use a separate folding table. The legs grab the original table mount to help keep it stable when folded for travel
  8. OneTruth
    OneTruth Member
    31
    Aug 18, 2019
    I seem to see a warp to my tabletop. Makes sense that you would not want to warp the tabletop
