converting to led lights
Discussion in 'Lighting, Interior and Exterior' started by JoeW22, Jun 28, 2020.
  1. JoeW22
    JoeW22 New Member
    27
    Jun 23, 2020
    Wisconsin
    I read many of you have switched to led lights in the pup..
    Do you just buy new led bulbs and replace?or is there something more to convert them?
    Where did you get them and how much are they? Part number would be nice..I'm assuming most campers use the same type of bulbs
    Thanks in advance
  2. tombiasi
    6,329
    1,881
    Just get the number off of your bulb and search for LED replacements. All you do is put them in.
    theseus, JoeW22 and Sjm9911 like this.
  3. slowcarfast
    slowcarfast Active Member
    83
    174
    Nov 5, 2019
    Sunshine State
    A lot of folks mention https://www.superbrightleds.com/. As noted, you look at your bulbs and search a replacement with the same designation. Replacements may be available with a variety of brightness levels (the brighter they are, the greater the power draw) and different light colors (warm to cool white). It might take some trial and error to get the combo you want.
    KeizerTrailer and JoeW22 like this.
  4. JoeW22
    JoeW22 New Member
    27
    Jun 23, 2020
    Wisconsin
    I cant see a number on any of the bulbs I checked unfortunately
  5. tombiasi
    6,329
    1,881
    Can you post a picture of the bulb? Bottom and base.
  6. JoeW22
    JoeW22 New Member
    27
    Jun 23, 2020
    Wisconsin
    This weekend if I remember..its put away for the time being
  7. JoeW22
    JoeW22 New Member
    27
    Jun 23, 2020
    Wisconsin
    I looked quick online..i think they are 921's
  8. Anthony Hitchings
    2,279
    1,248
    Mar 2, 2019
    Oakland, California
    YUP - thats what I did for the OEM fixtures.
    Then I added two overhead LED strip lights, just below the peak, which are fantastic for the Aliner..
    Thorofin likes this.
  9. Snow
    11,363
    2,004
    I bought all mine of Ebay, from China.. been using them for several years. Out of 8 fixtures, I've put LEDs in 7 of them ..
  10. Raycfe
    17,270
    2,858
    Screen Shot 2020-06-29 at 7.11.58 AM.png Do your research ...... because ceiling lights have no or poor reflectors you may want to look at a replace panel bulb. All the light goes in one direction there you want it.
    NorthernLights and JoeW22 like this.
  11. rabird
    7,616
    739
    N. TX
    previous owner put up 4 of these and one that is double.
    Haven't had a need to use more than one at a time
    IIRC ole PU used 1156 base
  12. Sneezer
    2,666
    1,498
    I bought mine from Amazon. Mine are closet in color to incandescent as I prefer that to a Joe vs the volcano vibe. I did make sure to get ones that were rated to a larger voltage range. I had read that some had problems with straight 12v ones due to voltage fluctuations. Mine are rated for 12-24v I think. No problems 4 years on now. Straight replacement bulb.
    slstarr1026 likes this.
  13. MNTCamper
    MNTCamper Well-Known Member
    1,270
    456
    Jun 14, 2014
    MN
    I would recommend that you just get SMD LEDs off of eBay. They are the flat ones and just stick in your fixtures. They come with multiple bulb socket adapters. All the light output goes where you want. Different lumens and colors available. They are about$1 each, often sold 10 at a time. Very easy to convert and install. The only thing you need to pay attention to is the polarity, they only work one way.
    JoeW22 likes this.
  14. tombiasi
    6,329
    1,881
    The ones you have have a regulator. I strongly recommend ones with a regulator. If you only use battery and never plug into AC then it wont matter much.
  15. Orchid
    Orchid Sharp Shootin' Grandma
    5,819
    2,732
    May 8, 2011
    Florida by way of WV and MD
    Either way. I replaced my interior fixtures in the pup because they were super cheap and I wanted pretty new ones. In our big TT, I just replaced the bulbs with LED.
  16. Dstinnett875
    Dstinnett875 New Member
    25
    22
    May 25, 2020
    Huntsville AL
  17. Thorofin
    Thorofin New Member
    26
    May 27, 2020
    Tampa, FL
    I'm thinking of doing the same thing in my Expedition. Can you post some pics and parts?
  18. slstarr1026
    slstarr1026 New Member
    Aug 7, 2019
    Which bulbs did you use? Do you have a link? Thx!
  19. JoeW22
    JoeW22 New Member
    27
    Jun 23, 2020
    Wisconsin
    This is what I got..im happy with them..could be brighter but just as bright as regular bulbs
  20. slstarr1026
    Aug 7, 2019
    Thank you!
