Copper Tubing?
Discussion in 'Miscellaneous Repairs & Maintenance' started by jmatasov, May 23, 2017.
  1. jmatasov
    jmatasov "Never tell me the odds." -Han Solo
    125
    17
    Aug 19, 2016
    Western NY
    So I had to cut one copper gas line to get the floor out. it was really in a hard-to-reach place so cutting it was the only option. I also have a larger line I need to replace.
    I took the pieces to Home Depot to get some replacement copper tubing and I noticed that the "L" tubing has super thin walls compared to the stuff I pulled out. Like paper-thin vs 1/16 or 1/32" thick. Something like 1/3 as thick as what was there.
    I need to use the thicker stuff, don't I?
  2. shaune509
    shaune509 Member
    32
    Aug 13, 2014
    spokane wa
    There are 2 grades of flex copper yubing. One for low pressure water service and the high pressure for gas and hvac. IMHO use the heavier grade.
    Shaune509
  3. jmatasov
    125
    17
    Aug 19, 2016
    Western NY
    I do want to use the heavier grade. Where do I even get it? I didn't see it at Home Depot.
  4. rabird
    6,700
    300
    TX
  5. Snow
    10,104
    1,027
    Contact a place that does gas bbq and fireplace installs, or chase down a gas company contractor and inquire how much it would cost for the feet you need ...
  6. SteveP
    SteveP Well-Known Member
    1,491
    405
    Or your friendly neighborhood Hank Hill, who sells propane and propane accessories.
    neighbormike likes this.
  7. sgip2000
    sgip2000 Member
    536
    Jun 16, 2010
    Hillsboro, OR
    Typically, K for High Pressure, L or M for Low Pressure; however, K can also be used for Low Pressure
  8. Boatnman
    Boatnman Well-Known Member
    1,444
    325
    Jan 19, 2017
    western Colorado
    "Fuel Oil, L.P. and Natural Gas Services Use Type L or Type ACR tube with flared joints in accessible locations and brazed joints made using AWS A5.8 BAg series brazing filler metals in concealed locations."
    from the Copper Tube Handbook
  9. justincdst
    justincdst Member
    36
    May 20, 2016
    Bring this back to life. I'm have to replace all my tubing or most of anyway. Is there such a a thing a rubber rubbing vs the copper stuff? Seems to work in the BBQ and from the regulator. Is it a cost thing cause it seems a high grade rubber one with fittings would be easier to work with.
  10. 94-D2
    94-D2 Happy Campin'
    2,278
    127
    May 21, 2010
    Sutter Creek CA
    I ran 3/8 tubing purchased from a local hardware store. Bought a flaring tool and fittings, worked like a charm. I stayed away from compression fittings due to all the shaking and movement of towing. I wouldn't run the rubber flex hoses very far. I installed stainless steel braided hoses from the tanks to the regulators. Make sure to leak test the lines, very important.
    As far as having the propane folks custom make lines for you, some will and some won't. Depends on their policy of liability. It's a touch subject I guess.
  11. nineoaks2004
    7,279
    3,022
    Dukes, Fl
    My new Coleman has rubber hoses ran down the length instead of copper and I have had no problem. , but if you use rubber make sure it is the kind that is lined on the inside.
  12. Novarich
    Novarich Active Member
    360
    34
    Dec 8, 2014
    As nineoaks2004 mentioned, use lined hose only for a permanent installation . The rubber hose breaks down inside on the regular propane hoses that they sell off of the shelf. The manufactures recommend that you use a filter to keep the deteriorated rubber out of your equipment.
  13. justincdst
    justincdst Member
    36
    May 20, 2016
    Hmm I didn't think of rubber break down. I have most of the old copper from when I removed the floor so I just have to replace the sections after the cutouts. Kind of cool each branch has an isolation valve. For inside the trailer is still ahve all the rubber hoses that came pre-installed. Thanks for the input.
  14. Customer
    Customer Well-Known Member
    2,436
    243
    Jun 5, 2014
    Be aware that compression fittings are not acceptable for LPG copper lines. They must be flared.
