Corner piece of popup? Corner Cap?
Discussion in 'Mystery Parts' started by ohyeah29, Jun 6, 2020.
  1. ohyeah29
    ohyeah29 New Member
    23
    Feb 12, 2018
    [​IMG] I am trying to figure out what the corner piece of the popup is called. I have a '99 Flagstaff and each corner has this square piece. It may be to hold the two sides together...I'm not sure. These are not on top of the roof, but rather on the frame of the popup. Maybe a "Corner Cap"?
    The reason I ask, 3 out of 4 of them are cracked/broken. I am not sure if they really NEED to be replaced or not.
  2. ohyeah29
    ohyeah29 New Member
    23
    Feb 12, 2018
    Any leads?
  3. brettstoner
    brettstoner Active Member
    100
    107
    Jun 17, 2014
    Toledo, OH
  4. WrkrBee
    WrkrBee Un-Supported Member
    6,548
    3,454
    Make them out of a heavy duty plastic storage bin.
  5. Mississippi
    Mississippi New Member
    Sep 28, 2020
    Did you find these? We just purchased a pop up last weekend and one of them is broken. The storage bin might work, but mine are not flat. They have a lip the hugs the bottom of the wall. What are they called?
  6. ohyeah29
    ohyeah29 New Member
    23
    Feb 12, 2018
    I did not. What was listed in the Amazon link is not the same thing, though. Mine are square and look to cover the corner pieces of the camper.
  7. Mississippi
    Sep 28, 2020
    I have the exact same thing. I have one that is broke now and hope to find a replacement soon. Thanks.
  8. Mississippi
    Sep 28, 2020
    I found what I think to be the corner caps at: https://robertssales.com/parts.html. They do not have a way to order online. You will need to call them. I just placed and order for 4 and they said they could ship them in an envelope for 5.00. Not sure where you are located, but I went ahead and placed the order. We will see what I get.
    Gray caps Gray plastic cap for box top corners, box door corners, can be cut to size, each $1
    TheGreatOutDoris likes this.
  9. Mississippi
    Sep 28, 2020
    I ordered the ones from robertssales and they came in yesterday. They appear to be the same as what was on the camper. I hope this helps.
  10. TheGreatOutDoris
    TheGreatOutDoris New Member
    Apr 13, 2021
    I COULD KISS YOU!!!!!
    I can find 4”x4” corner caps on Amazon, but they are meant for slide-put sections of a big ole RV. This is EXACTLY what I need! My 2006 needs the 4 corners AND one for each side of the door.
    THANK YOU!!!
