Covering Vent Opening
Discussion in 'Camper Restoration Projects' started by thombri421, Jul 21, 2019.
  1. thombri421
    thombri421 New Member
    Jul 21, 2019
    We recently purchased a new to us 1993 Coleman/Fleetwood Seneca. We are redoing the complete interior, with plans to work on the exterior in the fall. We decided we weren't comfortable with the old propane furnace for heat (we will get an electric heater instead) and removed it for extra storage. We've decided how we will cover up the hold on the inside of the camper, but aren't sure as to go about covering the hole on the outside. We we hoping to discover some sort of plate that would fit perfectly. The opening is approximately 3"x5". Any suggestions?
  2. Matt Benoit
    Matt Benoit Well-Known Member
    544
    334
    Jul 30, 2017
    Warren, MI
    Given that the hole already goes completely through to the inside, I'd suggest a pass through hatch. That way you could have access to the storage from the outside. If you just want to cover it, anything flat will work. Just seal behind it so it doesn't leak.
  3. Matt Benoit
    544
    334
    Jul 30, 2017
    Warren, MI
    thombri421 likes this.
  4. thombri421
    Jul 21, 2019
    Thanks for the suggestion! That is something we will definitely look into!
  5. nineoaks2004
    8,071
    3,608
    Dukes, Fl
    Some people go to Lowes or Home depot and get a louver to hide the dent / patch etc. and spray paint it the color of the unit.actually looks pretty good on some I have seen
    you will need to cover the hole with something like wide flashing or something
    similar before the louver is installed.
  6. Raycfe
    17,005
    2,578
  7. thombri421
    Jul 21, 2019
    Thanks!
