Crank storage?
Discussion in 'First Time & New Camper Owners' started by FARfetched, Jan 3, 2019.
  1. FARfetched
    FARfetched Well-Known Member
    737
    405
    Nov 22, 2018
    Sector 706, Planet Georgia
    I thought this would have been covered already, but I didn't find it in search. So… if your PUP doesn't have a front storage compartment, where do you keep the cranks? I just know I'm going to forget them some time. Or they'll get displaced, forgotten, and we'll spend a weekend tearing the garage apart to find them.
    One thought: a local biz sells ammo boxes; if I can find one tall (and wide) enough to hold the cranks, I could bolt it to the hitch or the back bumper. Maybe paint it to match the rest of the trailer. Has anyone done this?
  2. Katskamper
    Katskamper Active Member
    781
    224
    Nov 21, 2015
    Fort Worth, TX
    i tied a red ribbon to mine. when i put it up, i tie the ribbon to the propane tank. i can visually see its in its place before leaving. do you have any storage compartments?
  3. neighbormike
    2,807
    2,577
    Oct 6, 2012
    WI
    While camping, I always left it in the "crank" position... removed when cranked down and stored just inside the camper door.
  4. jmkay1
    5,784
    2,598
    My old Jayco the door could unlock and open without the roof needing to rise. So for me I just put it in the front cabinet in the camper. All I had to do was remember the keys. I like the amo box idea. There have been a couple people here who did something similar.
    lucky13don likes this.
  5. PopUpSteve
    PopUpSteve Administrator
    19,570
    2,192
    Dec 22, 2002
    Malvern, PA
    I have 4. Ok, 2 are actual cranks and 2 are electric lift switches. The actual cranks I keep one in the storage cabinet, just inside and by the camper’s door and the other in the trunk of the truck. The electric lift switches I keep in ammo boxes also stored in the same locations.
  6. tfischer
    tfischer Well-Known Member
    4,032
    1,511
    May 21, 2014
    My palomino has a pocket in the door where it stores.
  7. McFlyfi
    McFlyfi Well-Known Member
    578
    293
    Aug 1, 2014
    Thousand Oaks CA
    This is what I did with my Carmel. I also kept a spare crank in the truck at all times (under the back seat with the bottle jack).
    With the Niagara, the crank is readily accessible in the front storage, and the lift switch is in a little plastic box with a Socket Genie
    I still keep a spare crank and a spare electric lift switch permanently in the truck.
  8. FARfetched
    737
    405
    Nov 22, 2018
    Hey all, thanks for the suggestions.
    @Katskamper, I don't have any front storage. That would be the obvious place to store the cranks if I had. :) I checked out your blog and it gave me some ideas for other things I want to do later—especially adding a battery box. You have comments turned off, right?
    @jmkay1, the PUP is sitting out in my driveway, so it was an easy check: the door won't open with the roof down. I didn't think it would, but it wouldn't have been the first time I missed something obvious.
    There's a kind of triangular space between the propane tank and the camper proper. I might try to fab something out of thin plywood to span the hitch area. That should give enough room for a leveler, chocks, cranks, everything needed before opening the camper up.
  9. megcabra
    megcabra Well-Known Member
    2,469
    627
    Aug 12, 2015
    Chapel Hill, North Carolina
    Here is what we use since our Coleman Redwood door cannot open when the roof is down and no other external storage area exists on our model. The box has been bolted to the frame and the lid handle has been removed. And it fits/closes with room for nesting wheel chocks.
    J Starsky and FARfetched like this.
  10. Halford
    Halford Well-Known Member
    3,563
    569
    Sep 28, 2011
    Santa Clarita, California
    There is a storage compartment under the stepper door. this is a good storage for a jack and lug wrench and crank.
    Fless likes this.
  11. PeggyUSAFRET
    PeggyUSAFRET New Member
    Jan 2, 2019
  12. PeggyUSAFRET
    Jan 2, 2019
    I have a lot of storage in the front but also under the dining benches.
  13. BikeNFish
    BikeNFish Well-Known Member
    3,502
    2,357
    Apr 24, 2017
    Maplewood, MN
    I have an electric winch, but when I used pups with a manual winch, I always kept the crank inside the pup as close to the door as possible so it was handy when I needed it and always in the pup.
  14. tfischer
    4,032
    1,511
    May 21, 2014
    As I said above our pup has a special storage place in the door for the crank. But we keep leveling devices (Andersen, Lynx, and wood), the water hose (usually need it to fill the tank on the way in), and a few other "need immediately's) right inside the door.
  15. BillyMc
    BillyMc Well-Known Member
    1,645
    962
    Mar 25, 2018
    I suggest installing an access hatch door into an existing cabinet. An RV shop can handle this if you're not comfortable cutting a hole in your camper.
    Sorry that a kit that holds the door open. Here is a door.
  16. world traveler
    world traveler Active Member
    275
    25
    Oct 23, 2015
    Our crank fits nicely in the toilet access compartment, which is the only one accessible with the roof down.
  17. tfischer
    4,032
    1,511
    May 21, 2014
    I'd go nuts if I had to raise the roof, even partially, to open the door.
    neighbormike and FARfetched like this.
  18. Fless
    Fless Active Member
    971
    211
    Aug 14, 2012
    Colorado
    ^^^^ This is what I did with my '02 Cheyenne. Very convenient. In fact, when I bought the PuP and I opened that compartment the first time I found a new (probably old stock) bag of trail mix. [:D]
    I would never leave the crank in the "crank" position; I just wasn't comfortable leaving it there. It also might help to paint it a wild color so the chances of losing it go down.
    _
    Halford likes this.
  19. FARfetched
    737
    405
    Nov 22, 2018
    It would be nice if the manufacturers thought about that. :rolleyes: It's kind of like what I'm going through at work lately… pulling together documentation across several different product lines. A well-appointed PUP has itself, converter, fridge, A/C, awning, and who knows what else to document.
    Modern technical writing systems have the capability to remove information about stuff that isn't there, including pieces of wiring diagrams. My own work isn't quite as complex, since it has only three components (and they're all ours) instead of five or more, but still. At the very least, the manual for the popup proper could list what other documents are (or might be) included in the package.
  20. bols2Dawall
    bols2Dawall S.W. Ontario
    1,480
    168
    May 19, 2010
    Lasalle Ontario
    under the back seat of the tow vehicle
