De winterized the pup
Discussion in 'Camper Storage / Winterizing & De-Winterizing' started by crazymama30, Apr 7, 2019.
  1. crazymama30
    crazymama30 Active Member
    405
    174
    Apr 1, 2017
    Picked up the pup, flushed out the antifreeze. Things are working like they are supposed to, hot water heater, water pump, refrigerator and all with no leaks. If it weren't raining I could clean the canvas and re waterproof. I will have to make do with upgrading the curtain and valences.
    PopUpSteve likes this.
  2. Snow
    10,276
    1,127
    Did you sanitize the water system? and water hose ?
  3. crazymama30
    405
    174
    Apr 1, 2017
    Snow, I'm in the process of sanitizing the holding tank. I put the bleach solution and then ran the water to circulate it and let it set for a few hours and then I will go out and rinse it next. The hose is the one I always use so it should be ok, and we dont use the water from the trailer for drinking but do use it for cooking and cleaning.
    I need to reseal the roof as I have a couple little leaks, but I cannot address that until the rain stops.
  4. Nanapoppypops
    Nanapoppypops Member
    209
    Mar 30, 2019
    Would anyone be able to tell me the steps to de-winterize our 2009 palomino pop up? Thank you. Have never done.
  5. crazymama30
    405
    174
    Apr 1, 2017
    Tell me what steps you took to winterize it.
  6. Nanapoppypops
    209
    Mar 30, 2019
    We were not told at the dealer when we picked it up
  7. crazymama30
    405
    174
    Apr 1, 2017
    I would make sure the water heater is not bypassed, then I would run the water until it is empty, then fill the fresh water tank and flush it until the water runs clear, make sure you run the shower and flush the toilet if you have one. I dont have these options so hopefully someone else will chime in. After you have flushed with clear water I would add some bleach (how much depends on how large your fresh water tank is, Google for concentration) then fill your tank. I like to then run the water to circulate the bleach solution and then let it sit for several hours, then flush with fresh water. I usually run 2 tanks of water through it to be sure to get all the bleach out.
  8. Nanapoppypops
    209
    Mar 30, 2019
    I do not have shower or toilet. To flush the tank, I assume you do this from the outside of camper. Not sure how large my water tank is. We are new to pop up camping. I sure don't want the water running around inside and nothing has been turned on yet. Thanks for your help with our Senior camping
  9. crazymama30
    405
    174
    Apr 1, 2017
    Is this a brand new or used pup?
  10. Snow
    10,276
    1,127
    Look on youtube for "de-winterizing rv" take note that most of what you'll get are for large Motor Homes (MoHo's) and 5th wheels but the basic principles will be the same, then all you need to do is reverse the procedure for the features you have.. I actually think there is a video or two for a popup.. might be called a "tent trailer" ...
  11. Nanapoppypops
    209
    Mar 30, 2019
    It's a 2009
  12. crazymama30
    405
    174
    Apr 1, 2017
    you tube is a great option, I have used it for several things
  13. Nanapoppypops
    209
    Mar 30, 2019
    Thank you
  14. Nanapoppypops
    209
    Mar 30, 2019
    Hi there from Lake Placid! Due to some fluctuating temps in our area, I am about to de-winterize the 2009 palomino pup. I got ahold of the dealer again, who told me the 20 gallon water tank was empty upon our purchase back in April. They did tell me that I needed to get the antifreeze out of the water pump tank. I have no idea how to do this. I cannot find an anode or any bypass that may have been done previously. Anyway, by sending this pic of what I hope is the hit water tank, I may be able to get some help. Thanking those in advance for putting up with new camper.
  15. Snow
    10,276
    1,127
    As per your other post.. that is your furnace with the inside cover removed..
