Death to fuzzy tail tree rats!
Discussion in 'Camping Around Wildlife' started by BillyMc, Feb 20, 2021.
  1. BillyMc
    BillyMc Well-Known Member
    2,303
    1,632
    Mar 25, 2018
    This week I've been testing stuff on the new to us hybrid. Furnace and fridge work great and was going to hook up water and test the water heater tomorrow being they aren't calling for freezing weather after tonight for a while. I had to go to the store for DW and when I returned and got out of the van I smelled gas. I put down the stuff from the door to find where it's coming from. The house has gas heat, that wouldn't be good tonight with temps in the 20s. As I walked between the camper and the garage I could hear the hiss coming from the camper. One of those @#&$%*! has chewed a hole in the line from the tank to the regulator. I'm done deterring these destructive rodents from constantly chewing on our stuff. Death to them all!!!!!!!!
    Pommom70, rescamilla, aan1129 and 5 others like this.
  2. WrkrBee
    WrkrBee Un-Supported Member
    6,538
    3,448
    Hard to beat a .410 for that application. We had to pull the bed, on my son's Mazda pickup, to repair a gas line damaged by the elevated tree dwelling buck tooth rodents.
  3. kitphantom
    13,216
    2,323
    rodent deterrent is one reason we went to using the braided stainless covered lines on the tanks to regulator, also so the rubber isn't as exposed to the UV. I'm sure it's not foolproof but it's a start.
  4. Sjm9911
    10,626
    8,008
    Agreed, happened to me also. The rubber lines are like candy to them.
    DiamondGirl likes this.
  5. Snow
    11,800
    2,380
  6. Susan Premo
    Susan Premo Well-Known Member
    629
    337
    Nov 5, 2020
    Minnesota
    I know!! We have too many grays, so when a red squirrel popped up in our yard about 2 months ago, I was happy to see it, I got to watch it chase red squirrels out! That was fun, hopefully red isn't a bad chewer of aforementioned lines.
  7. BillyMc
    2,303
    1,632
    Mar 25, 2018
    Unfortunately, discharging a firearm where we live is prohibited. Fortunately, a Benjamin .22 cal. air rifle is quite lethal and isn't considered a firearm where we live and I just happen to own one and a couple thousand pellets for it. Warning some areas that are less gun friendly consider anything over .177 cal. a firearm.
  8. BillyMc
    2,303
    1,632
    Mar 25, 2018
    Never seen a red around here, but Fox squirrels were common when I was young. It's rare that I see them now, these little grey tree rats are everywhere though.
    DiamondGirl and Susan Premo like this.
  9. Susan Premo
    629
    337
    Nov 5, 2020
    Minnesota
    Fox squirrels are pretty, I don't think they come into people areas, just in the woods. But, I was surprised to see a red around here, but were close to the Mississippi river.
  10. DiamondGirl
    DiamondGirl Adventures with KODI in AZ
    1,113
    1,089
    Jul 2, 2016
    AZ
    Where I’m at in the desert... We have gopher issues. I’ve lost 6 Red Yuccas, 2 Purple fountain grass plants and a Blue Agave Cactus. We’ve tried everything to deter them. No such luck. We have cats so no issues with mice/rats. My last cat took out three gophers but there’s a group of them in the neighborhood.
    Happy Camping...[put&hy]
    rescamilla and Susan Premo like this.
  11. kitphantom
    13,216
    2,323
    And then, there's the whole thing with pack rats at (some) campgrounds in AZ. When we were at Lost Dutchman a couple of years ago, it took us a bit to figure out why all the hosts had rope lights or such under their RVs; one had a shop light under their truck (that was very annoying, since it was not aimed well and blinded anyone walking on the road). Finally it dawned on us that it was in aid of repelling pack rats. The friends camping with us had been advised, at another campground, to leave their hood open. They sort of poo-pooed it, but decided to see if there was a spot a pack rat could built a nest - in less than half an hour, there had been vegetation deposited on the top of a head light. it is a problem here in NM too, especially in the East Mountains, Even at home, we had one set of ignition wires on our truck chewed by a ground squirrel.
  12. Susan Premo
    629
    337
    Nov 5, 2020
    Minnesota
    Sounds more like a "gang"!
    DiamondGirl and rescamilla like this.
  13. Sjm9911
    10,626
    8,008
    Just watch out the squirrels are arming themselves.
    Westcoast and rescamilla like this.
  14. BillyMc
    2,303
    1,632
    Mar 25, 2018
    New line (steel braided) on the way and wallet $30 lighter. Actually spent more than that. Ordered a 12' hose with quick connect fitting so I can T into the low side and use the stove from the PUP outside in the awning enclosure.
    rescamilla, kitphantom and Sjm9911 like this.
  15. Shadowfax
    Shadowfax New Member
    Aug 28, 2020
    Firearms are prohibited where you live? Time for a change of scenery!
  16. aan1129
    aan1129 Member
    31
    39
    May 19, 2019
    We had fluffy tailed-floppy earred ground hoppers chew through all the wiring on a hot tub. I sure miss that tub. Right there with you!
    rescamilla likes this.
  17. wtyrrel
    wtyrrel New Member
    Mar 28, 2020
    Depends on the law; most cities have ordinances against discharging firearms in city limits; our cities do, as well.
    The air rifle isn't included because it literally isn't a fire arm; there's no fire. Not sure if they're trying to ban guns or just cared about the noise.. air rifles are much quieter (because no fire.)
    My dad has a 1 pump air rifle .177 that has a 1400 ft/s firing that will kill squirrels (using field pellets). Not all air rifles are made the same :p
    His neighbor uses traps which are much more effective.. squirrels seem to hate him - they've eaten several holes in his house into his attic; chewed a hole into his wooden deck (couldn't believe that one); and chewed up the wiring on both of his vehicles that were parked in the driveway. That's why he started using traps.
  18. Camperboy#13
    Camperboy#13 New Member
    May 6, 2016
    I use a .22LR snake shot cartridge in my .22 revolver. I pick off Red Rats here at my house and it isn't as damaging as the .410 :)
    Rik Peery likes this.
  19. 1380ken
    1380ken Well-Known Member
    2,759
    1,175
    Nov 7, 2013
    Mass
    I had squirrels in my eaves two years ago. I started trapping them in my havahart trap. I caught over 50 squirrels in one season. It got to the point where I didn't even have to bait the trap. I think the trap smells like a squirrel so much that it attracts them.
  20. zak99b5
    zak99b5 Active Member
    321
    213
    Feb 21, 2019
    And after they’re in the trap, it’s time for a swimming lesson!
    Old_Geezer likes this.
