Diesel heater
Discussion in 'Heating / Cooling Systems' started by bobinfleet, Mar 13, 2020.
  1. bobinfleet
    bobinfleet Active Member
    521
    215
    Sep 2, 2011
    Hampshire UK
    Just had a couple of nights camping and testing the diesel heater I fitted, and so far it has been great. Night temps about 5c and inside nice and toasty, I left all the insulation at home and the heater worked a charm.
    generok and Sjm9911 like this.
  2. mk4
    mk4 New Member
    Nov 20, 2014
    Fuel pump tick is a little annoying.
    Heat output (5kW) works well for me in temps down to the 20's.
  3. gladecreekwy
    796
    955
    Sep 25, 2016
    Jackson Hole
    So there is a tank of diesel somewhere?
  4. MNTCamper
    MNTCamper Active Member
    940
    228
    Jun 14, 2014
    MN
    Most of the units from China come with a 5l or a 10 l tank, mount it where it makes sense. A 10l tank would likely last at least a week, they sip fuel. Battery drain is a bigger issue.
    gladecreekwy likes this.
  5. gladecreekwy
    796
    955
    Sep 25, 2016
    Jackson Hole
    Interesting. I don’t know if I’d want the tank inside. Legal to mount outside?
  6. bobinfleet
    521
    215
    Sep 2, 2011
    Hampshire UK
    This is my set up, I didn't want diesel inside either. I have used a regular fuel container instead of the one supplied. The pump is wrapped in foam and is quiet. Anyone interested should look at this guy, John McK 47 on youtube
  7. MNTCamper
    940
    228
    Jun 14, 2014
    MN
    John for sure has the best videos on the web on this subject. These heaters can and are installed in many locations. They are efficient and safe. Frequently installed in campervans, they work great when operated correctly.
    bobinfleet likes this.
