Difficulty removing copper propane line
Discussion in 'Propane - Got Gas' started by DIY-Bri, Aug 6, 2019.
  1. DIY-Bri
    DIY-Bri New Member
    Jun 26, 2019
    Hello -
    I removed the old propane heater in my 1970 Starcraft Starmaster, however I am having trouble removing the copper line that fed that particular system.
    It sure looks like a wrench would loosen this, but attempting to rotate it twists everything and would bend the pipe if I continue to wrench on it. Any ideas on how to remove this specific copper line?
  2. tombiasi
    5,864
    1,421
    Go to a plumbing store and tell them what you need to do and they will probably have the solvent you need to loosen that. If it fails you may need to cut the tubing and start over.
    DIY-Bri and Sjm9911 like this.
  3. Sjm9911
    6,554
    3,930
    Penetrating oil. Soak it. It depends on if its oxidized together. If you have to cut it you could buy a flare tool in order to reconnect or cap it. There a bit tricky to use. Or you could leave the line as is and cap the end.
    DIY-Bri likes this.
  4. DIY-Bri
    DIY-Bri New Member
    Jun 26, 2019
    Perfect, this worked great and released it. Thanks everyone for input.
    Raycfe and Sjm9911 like this.
