Dinnette slideout clearance issues
Discussion in 'Slide-Outs / Bunkends' started by donaltman3, Oct 19, 2020.
  1. donaltman3
    donaltman3 New Member
    22
    Oct 14, 2020
    South Georgia / North Florida
    I have an 03 Coleman Niagra with a middle slide out for the dinette. This thing seems to be sliding out very roughly. Do they normally roll or glide out? We put new peel and stick flooring down in the camper and now can visibly see the bottom edge of the slide-out on the inside is rubbing the floor as it is pushed in an out and it looks as if it has done this for some time. The edges on the inside portion are chipping as it is slid in and out. Before you wouldn't notice it because the floor was a yellowish-brown and so was the sawdust/wood shavings but now it is a dark floor we are able to see exactly where it is rubbing. I also have to "bump" the slide with my weight to get it to go all the way in.. I guess because towards the end it is contacting the floor as if it is leaning some.
    What should I be looking for to try to fix this? How much clearance is between the bottom of the slide-out and the floor inside usually?
  2. pmt
    pmt New Member
    28
    May 29, 2018
    GTA, Ontario, Canada
    The slide out is on several rollers and shouldn't be difficult to push in and out. Each side has a metal wheel in a track and there are 2 or 3 flat rollers in the middle. In the attached photo from my 2008 Avalon you can see one of the flat rollers on the left, and the wheel in the track on the right.
    There should be enough clearance at the bottom to get a fingertip through, and mine has a rubber sweep at the bottom to close the gap.
    I would start by taking the front cover off and inspecting the rollers. The bolts cam come out of the rollers over time.
    Let us know what you find.
    02ColemanMom and flingwing1969 like this.
  3. donaltman3
    22
    Oct 14, 2020
    Great thank you for sharing this. The middle rollers were out of adjustment.. in fact on one of the two in the middle roller pins the cap had come off and the roller was not level causing that side to drop. We fixed that and adjusted it a little higher and now have no clearance issues. Thank you for helping. We did notice what looks like two more in the center rear of the slide but not sure how they are accessed.. by quick glance it looks like maybe the outside panel comes off to get to them. Thankfully I don't think I need to adjust them any !!! I was so tired and discouraged when we found this issue.... we have been remodeling it getting ready for our first trip. Very relieved to have gotten it squared away, thanks again!
    flingwing1969 likes this.
  4. flingwing1969
    flingwing1969 Active Member Silver Supporting Member
    614
    165
    Jul 6, 2013
    California Cascade Range
    I don't have any fancy-pants slide out but those rollers look to be almost identical to the rollers on a sectional garage door.
  5. pmt
    pmt New Member
    28
    May 29, 2018
    Glad you got it fixed up! Those rollers are a bit of a pain to access and maintain. One of the rollers is missing on mine from before I owned it but everything works fine without it.
    I also thought about installing better rollers and wheels with bearings but it seems to work fine as it is.
    Thanks for following up!
  6. pmt
    pmt New Member
    28
    May 29, 2018
    You're right, the wheels on the sides are exactly the same as a garage door! The middle rollers are more like metal cylinders though.
  7. 02ColemanMom
    02ColemanMom New Member
    Jul 16, 2013
    Massachusetts
    Hello, I'm so glad to find this post! I have a 2002 Coleman Niagara Elite and I'm not as young or strong as some of you out there, so I really have to lean into the slide to get it closed. I'm exhausted by the time I get set-up (which I have to do solo most of the time now). Once the snow melts, I plan on getting a closer look at the slide. Would any of you have additional pics and info on the dinette and how you repaired it? Even just pulling the inside panel off? I'm nervous about breaking something as I try to access it. I also noticed the bottom edges of the slide out has areas where the plastic/fiberglass has chipped off and there is only the wood left. Can that be repaired by a newbie? Thanks in advance for your help!
  8. donaltman3
    22
    Oct 14, 2020
    To access the bottom of the slide to see the rollers from the inside, you remove the step facing it is secured by a few Phillips head screws. Without the 6-8 inch tall step/kick panel in place, you can easily see all the rollers. If the slide is not level it would make it hard to either open or close depending on which way it was slanted. Also, the rollers on the sides could be off just a bit making your slide slightly angled left to right, which also could make it hard to push in and out.
    My slide now goes in and out fairly easily and does not get "hung up" as it used to.
    As far as the chipping or cracks on the bottom edges. I simply used white marine silicon. I went with 3M brand 5200. It is some serious stuff. Mainly to keep it waterproof and not looking bad. While I had this stuff out, I took the time to seal around all the hatches, doors, and light.
