Disconnect battery between trips?
Discussion in 'A-Frame PopUps' started by cambo, Aug 13, 2019.
  1. cambo
    cambo Member
    30
    Jun 15, 2019
    Hello, I have a 2012 Aliner Classic. It seems odd to me for the battery to be hooked up between trips draining the battery. Do you guys disconnect the battery between trips?
    Thanks
  2. GreyFox
    GreyFox Well-Known Member
    1,367
    629
    Oct 10, 2018
    S Ontario
    Of course, otherwise parasitic draw on the battery will kill it in just a week or two. You can physically disconnect it or for greater convenience install a battery disconnect switch. I use a Blue Sea m-series switch.
    https://www.bluesea.com/products/category/11/37/Manual_Battery_Switches/m-Series
  3. xxxapache
    2,868
    860
    Depends on how much parasitic draw you have. I don't disconnect my TT.
    Rik Peery likes this.
  4. Rik Peery
    Rik Peery Well-Known Member
    686
    562
    Jun 15, 2018
    Virginia
    I use a battery tender usually, but have disconnected until it reaches 50%, then recharge...only thing on mine is the detector...
  5. bheff
    bheff Well-Known Member
    815
    365
    Feb 24, 2011
    NW Arkansas
    I remove mine and place it on a battery tender.
    HappyTraveler likes this.
  6. tfischer
    tfischer Well-Known Member
    3,512
    1,021
    May 21, 2014
    I pull the fuse on ours, disconnecting it. We store offsite with no power for battery tender but that hasn't caused any issues. We bring it home a day or two in advance before a trip which is plenty of time to top off the battery from any latent discharge.
  7. BikeNFish
    BikeNFish Well-Known Member
    2,853
    1,760
    Apr 24, 2017
    Maplewood, MN
    I always disconnect.
    kcsa75 likes this.
  8. gladecreekwy
    671
    718
    Sep 25, 2016
    Jackson Hole
    Pull the fuse
  9. WrkrBee
    WrkrBee Well-Known Member
    2,433
    932
    No parasitic draws on our Scout. I keep a small solar charger on the battery. Even with the solar charger under the camper cover, it shows it charging (tells you the cover isn't doing much). Before camping, I bring the camper to the house and put a Schumacher charger on the battery to top it off.
  10. Zephyr
    Zephyr Active Member
    287
    53
    Jun 18, 2013
    central Oregon
    The only draw on our battery is the CO/propane detector, so I just pull the fuse when the pup is hibernating. Just remember to reinstall it when you head out...…..
  11. tenttrailer
    3,152
    297
    Jul 18, 2013
    Thornville, OH
    Yes, indirectly I disconnect the battery via a switch
  12. Raycfe
    15,189
    1,420
    I only disconnect or remove the battery when not plugged in. Either way I want the battery to be fully charged all the time.
    shuang2 likes this.
  13. aardvark
    aardvark Member
    36
    May 30, 2016
    Mine will discharge, just as the others have said. Plugging the camper in a day before will ensure that it is fully charged (my plug is not wired to charge it while I drive).
    That being said, I tried disconnecting a battery terminal and pulling out the fuse, and both were a pain. Finding the fuse can be a nuisance in the dark at setup, and the fuse holder corrodes more quickly with nothing in it. Disconnecting a terminal is also a nuisance, both because there is no place to put the terminal and because it's a nuisance to re-attach. I installed a battery disconnect switch, which cost me about $15.
  14. kcsa75
    kcsa75 Well-Known Member
    2,916
    1,323
    Sep 9, 2013
    Kansas City
    I always disconnect the negative cable on my battery when I put it in storage. Takes about 20 seconds.
    shuang2 and Rik Peery like this.
