J Starsky
One main problem I always find is that the grills need that finite amount of adjustment to keep an egg from running away! GRRRR I'm usually set up for 5+ days in a row, and I switch off from a table top grill and my Blackstone. You can twist a bolt down in three corners, making it easy to level. No more run away eggs. No more corners of boxes sticking under the side of your grills.
I also added wood runners on to our 50 gallon blue storage bins, off in the background. The bins actually slant, to look sleek but left us zero safe place to set a bin or coffee cup without falling. The planks are leveled and bolted down to the bin top. They open and close perfect.
This was 4x4 piece of 1/2in sanded 1 side oak handy panel. Fasteners from around the garage. Stained and sanded twice. A few coats of Poly Coated. Menard's lady helped me pick it out - really haven't done any staining projects. Said heat and sun and water or grease should be be fine on it. I've been out three times this summer, works good![Big Smile [:D] [:D]](/smileys/smile_big.gif)
What do ya think huh? We just walk the bins out from the TT as the 1st thing unloaded.
Bin on the left has all the pots, pans, serving trays, foil, paper goods, spices - everything cooking. The right Bin is for my Grills. I fit a tabletop grill, dual burner coleman, the Blackstone wrapped in a towel - plus the Grill Leveler, couple propane tanks, tea kettle and grill tools o'plenty!
![Modification [MOD] [MOD]](/smileys/smile_wrench.gif)
![Question [?] [?]](/smileys/smile_question.gif)
![Chef [CK] [CK]](/smileys/smile_chef.gif)
