Do I have a Goshen lift?
Discussion in 'Lift Systems' started by NoleFan, Apr 8, 2019.
  1. NoleFan
    NoleFan Member
    31
    Jun 28, 2017
    I assumed all Starcraft's had a Goshen lift, but upon calling Goshen to inquire about safety posts for my 1995 Starcraft 1224 Starlounge, the lady didn't have that model noted.
    They have 2 different sizes.
  2. NoleFan
    NoleFan Member
    31
    Jun 28, 2017
    And also, I would be ok using some 1x4s or something, but how would you get a tight fit? I don't want to risk opening the lift system too far.
  3. Grandpa Don
    Grandpa Don Well-Known Member
    559
    298
    Sep 5, 2018
    The Goshen lift system has only one cable running in a tube under the camper. All four lifting springs and corner tubes are connected to the one center tube. If that is what you have, then you have a Goshen system which needs safty posts. The other type system is called a Whiffletree system (sp?). I don't believe that system required safety posts. Take a photo underneath your camper and post it here. I have no experience with any type of lift other than the Goshen system.
  4. NoleFan
    NoleFan Member
    31
    Jun 28, 2017
    Thanks, will take a picture and post!
