Do my breakers need to be on for battery to charge?
Discussion in 'First Time & New Camper Owners' started by 1Step, Nov 15, 2019.
  1. 1Step
    1Step New Member
    Sep 21, 2019
    San Diego
    When the pup is plugged into shore power (either at home 110 or on site 30amp), do the breakers need to be on for the battery to get charged?
    I am so confused about getting juice to the battery!
  2. bheff
    bheff Well-Known Member
    1,504
    920
    Feb 24, 2011
    NW Arkansas
    Why would you turn your breakers off?
  3. 1Step
    1Step New Member
    Sep 21, 2019
    San Diego
    I presumed that having them on somehow kept a current running to/from my battery.
    Not feeling overly intelligent at the moment and guessing I am completely wrong in my assumption and displaying my total lack of electrical knowledge!
  4. jmkay1
    5,783
    2,597
    No. Although every converter is different usually for your age camper there is absolutely nothing special you need to do. I would take a multimeter and measure the battery voltage while it’s plugged in. If it reads 13 or close to it, it is charging. If not, then something may be wrong.
    neighbormike likes this.
  5. joet
    4,997
    1,070
    They need to be on. Your convertor needs AC power in order for it to charge your battery
    kitphantom and Raycfe like this.
  6. bheff
    1,504
    920
    Feb 24, 2011
    NW Arkansas
    Yes, most all converters need the breakers on. Unless you are working on a circuit there is no need to flip the breakers "off".
    You have 2 means of electricity. Battery and shore power. When connected to shore power your battery isnt used. The converter sends out power to both the 12 volt side (dc) and 120 volt (ac) outlets. Your outlets will NOT work on just battery power. The battery powers the lights, water pump, heater fan when not on shore power.
    Your fridge will work best on propane. Dont use 12volt unless traveling down the road. (Even then I still use propane)
    1Step, neighbormike and kitphantom like this.
  7. GreyFox
    GreyFox Well-Known Member
    2,435
    1,260
    Oct 10, 2018
    S Ontario
    Not true at all - a converter has nothing to do with the trailer's 120 vac system other than being a convenient place to physically mount breakers on it's front panel. It's a logical solution as 120 vac has to be connected to the converter's input anyway and avoids the need for a separate breaker box. In some smaller campers (many popups for example) one of the breakers protecting a couple of 120 vac receptacles will often also be wired to protect the converter, in larger trailers (travel trailers, 5ths, etc) the converter is often protected by it's own breaker. In this latter wiring scheme one could switch off the converter completely yet still have 120 vac feeding all the various duplex receptacles in the camper.
    Anthony Hitchings likes this.
  8. Toedtoes
    Toedtoes Well-Known Member
    2,342
    2,189
    May 28, 2018
    The converter is usually a converter/charger.
    The charger portion takes the shore power (or generator power) to charge the battery.
    The converter portion takes the shore power (or generator power) and converts it to 12v power to operate the lights, water pump, heater fan, and any other 12v functions in your camper.
    The outlets are powered directly through the shore power (generator power).
  9. roybraddy
    roybraddy Well-Known Member
    2,383
    919
    Mar 23, 2016
    King George, Virginia
    I always have a multimeter around... I also have a 12VDC Panel just inside my entrance door that is directly connected to the batteries... My batteries read 12.5-6 VDC when switched out just sitting there. If I want them to be charged I have to see this DC VOLTAGE to jump up to over 13VDC...
    If you don't see the higher DC Voltage across the battery terminals then the batteries are not being charged...
    Do whatever you need to do with your breakers to see an increase in DC Voltage across the battery terminals...
    Roy Ken
  10. Anthony Hitchings
    1,560
    812
    Mar 2, 2019
    Not really, IMO your loads are always on the battery bus unless you have an unusual converter with a relay to isolate battery bus from load bus when charging (which also means that you would need to need careful on how you wire up downstream equipment, else you would defeat such a feature). My new Progressive Dynamics "converter" does not have this split personality (I checked with P.D.) (the older model might have). So unless you have a split personality rig - there can only be one flavor of 12- 14V on the bus shared by the battery and loads. Given how much trouble many PUP owners have with electrical issues, I can't imagine the "converter" manufacturers adding such complexity.
    The rub here is that I had looked at some old P.D. converter literature, and thought that my new converter was going to give me this feature. No such luck. But given that I have a PV system, its just as well. Things are sufficiently complex with just a common bus.
