do u know Y propane burner is a tourch
Discussion in 'Propane - Got Gas' started by rickhise, Jun 7, 2007.
  1. rickhise
    rickhise New Member
    72
    Apr 14, 2007
    one of my burners on the built in stove is like a blow tourch knob doesnt control it a bit. is this repairable? this is an older unit
  2. Leyster
    Leyster Revelstoke, B.C.
    343
    Jul 22, 2005
    Revelstoke, B.C.,Canada
    Seems to me this would be the mixture of air to the propane. On the gas stoves in the kitchens I work in there is a screw under the stove top to adjust this mix to get the flame to a nice blue with a yellow tip. Not sure if the pups have this as have not used our burners inside or taken the top off yet. Hope this helps.
    2 happy campers and Autumn the backpackin dog
    http://community.webshots.com/user/leysterg
    14 days camping in 2007
  3. rickhise
    rickhise New Member
    72
    Apr 14, 2007
    no this isnt a slight adjustment issue the flame is major, and dangerously out of control, had to get outside and shut off the tank valve, it seems like all the gas is coming through this one burner, didnt know if it had a packing in or what ever thanks, the stove knob didnt phase it.
  4. Yellowkayak
    2,198
    Mar 13, 2007
    SOunds like your lines are slightly clog. Detach both ends and get an air compressor (high volume) and blow out anything in the line. If this doesn't work, then you have to replace the burner part of the stove. Make sure you use pipe tape on the connections when putting it back on. Let us know what you find.
    07 Chevy Trailblazer
    07 Chevy Crew Cab
    07 Fleetwood Niagra
    (2) Hobie Adventure Kayaks
    (1) Hobie Outback
    (1) Pungo 120
    (1) Pungo 100
  5. John L
    John L New Member
    520
    Aug 15, 2006
    Vermont
    If you use tefflon pipe tape make sure it's the yellow tape made for propane.
    John & Kitty (Empty Nesters)<img src=../Images/icons/icon_smile_camping.gif border=0 align=middle>
    '02 Coleman Cottonwood <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle>
    http://community.webshots.com/user/VTWoody
    '97 Silverado X-Cab Stepside <img src=../Images/icons/icon_smile_suv.gif border=0 align=middle>
  6. rickhise
    rickhise New Member
    72
    Apr 14, 2007
    thanks for both tips, will try the blow out and no idea about different tape on propane thanks
