Do you exchange or refill your propane tanks?
Discussion in 'Propane - Got Gas' started by PopUpSteve, Sep 10, 2010.
  1. Exchange
    74 vote(s)
    18.7%
  2. Refill
    307 vote(s)
    77.5%
  3. I make my own gas, pass the baked beans!
    15 vote(s)
    3.8%
  1. PopUpSteve
    PopUpSteve Administrator
    20,015
    2,934
    Dec 22, 2002
    Malvern, PA
    Word of caution about NEW LP tanks. Make sure the tank is bled completely at the first filling of LP. And WATCH the person do it! When I got my tank filled the first time I forgot to tell the guy it was a new tank and he didn't bother to bleed it. So the tank was only 3/5 full. The next guy I told and he said "ok" but still didn't bleed the tank. I don't think his English was all that good and he did't understand what I said. I finally took it to a place where the guy knew what he was doing and I managed to get just shy of 17 lbs of LP.
    Also, I've found that some refill stations around my area are charging $20 to refill, no matter how much they put in the 20 lb tank. If they do refill a completely empty tank (17 lbs = just over 4 gallon of LP), then you just spent $5 per gallon. That about $.61 per gallon or $2.44 per tank more then my local U-Haul dealer. So check the refill stations policy before refilling your tank. If you still have a little LP left in the tank, it could really cost you.
  2. RotnMom
    RotnMom Am I there yet?
    4,125
    Apr 4, 2011
    I have 2 twenty pound steel tanks and 2 seventeen pound Clearview tanks. I'll be testing the Clearview tanks this year. Mounting with black rubber super bungees as I don't have time to have brackets remade. The Clearview tanks are taller.
    Anyway, I filled both Clearview tanks and I don't think it was more than around $14 and change each.
    [:D]
  3. chefaleslie
    chefaleslie Always looking for a great MOD
    294
    28
    Feb 9, 2013
    Sisters, OR
    I wish they had a exchange for Batteries, I'd pay $20 for a full one :)
  4. Ken1967
    Ken1967 Can't wait to Camp!
    1,071
    Apr 9, 2010
    Refill on trailer. Exchange on at home grill
  5. BuxCamper
    BuxCamper Member
    318
    Mar 29, 2003
    Bucks County, PA
    I refill but I have a tank coming due for inspection. That one I'll exchange. I can pay for the cert or just let be in the cost of the exchange. I'll just look for a probably was new and empty when exchanged and grab that. A buddy got a re-certified tank in an exchange. It had a current date stamped on it but a less than stellar re-paint job.
  6. Ridge-Runner
    Ridge-Runner New Member
    393
    Feb 25, 2014
    Before you do that make sure it is not a PRE PURGED tank.
    We sell New Worthington tanks and they are Pre Purged ready to fill they come with a Vacuum pulled on them from the factory so if you insist on watching him bleed off the air you are actually FILLING the tank with air not removing it.
    On tanks that are NOT pre purged they should have a LITTLE bit of gas put in them and then bleed it off and repeated 5 times before being filled
  7. JungleJim
    JungleJim New Member
    990
    Feb 25, 2008
    Mounting with bungees? "Black rubber super bungees" or whatever type of bungeeĀ… are there regulations on how tanks are mounted?
  8. JungleJim
    990
    Feb 25, 2008
    Exactly. Why pay more to get less? Most people don't realize the refill tanks are purposely never completely filled.
    I want my propane to last as long as possible.
  9. Wild-Life
    Wild-Life Active Member
    617
    35
    Jun 22, 2012
    North Carolina
    My tanks are kept out of the weather and are in good condition. The original from our PuP had an 04-02 date on the collar so I took it this morning to recertify.
    For anyone in the Raleigh, NC area, Apex Propane does the recertification. It took about 10 minutes and cost $5. Personally, I have never done a tank exchange. I tend to purchase and keep things till they wear out.
  10. hotrodcamper
    hotrodcamper Member
    972
    19
    Nov 3, 2012
    I have them refilled. Occasionally have them recertified. Cheaper than exchanging them.
  11. PopUpSteve
    20,015
    2,934
    Dec 22, 2002
    Malvern, PA
    Locally, the Refill and Exchange rates are just about the same, $20. What are the current prices in your area?
  12. Wayne In Florida
    Wayne In Florida Member
    301
    Jul 5, 2013
    I can get a refill for 14.00 and tax here in Florida
  13. F239141
    F239141 New Member
    285
    Jul 19, 2014
    I refill, I'm anal and all my tanks are nice and clean, a few have gauges. I'm slowly replacing all my tanks with tanks with gauges. I'm working on getting 2 tanks for every gas item I own (house grill, camp grill, portable fireplace) and 3 for the pup. Right now I have 5 20lb and a 110lb back up for the house. Looks like I have 4 more to go.
    The place I refill gives you your 10th refill free, it hovers around 2.50 a gallon
  14. chefaleslie
    294
    28
    Feb 9, 2013
    Sisters, OR
    I re-filled at $13.50 a tank the other day.
  15. JimmyM
    JimmyM Well-Known Member Gold Supporting Member
    3,136
    1,121
    Jun 5, 2014
    Franklin, MA
    In the past I had refilled my nice shiny white tanks, but after a couple of "oops I ran out of gas" events where the only place available was an exchange place I eventually had 2 exchange tanks. So I exchanged after that. I had a changeover regulator and an indicator, but after it switched over, I forgot to refill when I got home. Oops.
    With my upcoming HTT I was thinking of buying 2 30# tanks. If I do, I'll only refill of course. If I'm dopey enough to run out, I'll just buy and exchange 20 pounder.
  16. Winchested
    Winchested Member
    321
    Jun 19, 2015
    I have 3 tanks now as I got two with the pup. All exchange tanks. Only two places round me refill bout $17. So I will refill now until the tanks need a recert then I exchange them. Never had a bad exchange tank. Always freshly painted with new valves.
    Recert on 20 lber is only an external visual anyhow.
  17. 64osby
    64osby Member
    243
    May 11, 2015
    All the exchange places around us have gone to only filling the tanks with 15 lbs. I get mine refilled unless it is no longer working or really old.
  18. ChocoChock01
    4,025
    22
    Mar 7, 2012
    I exchange when the tanks are at or past expiration on the tanks!
  19. FL_Bill
    FL_Bill I'm cooking something yummy!
    983
    Aug 3, 2011
    Saint Petersburg, Florida
    I do both....
    Depends on age of tank and time frame.
    FL Bill
  20. redneckgearhead
    redneckgearhead New Member
    375
    Mar 30, 2015
    My local gas station fills them until they won't hold anymore which is great until it starts venting in the back of the truck....
