Do you plug space heaters into the pup outlets?
Discussion in 'Heating / Cooling Systems' started by higginskatie, Mar 28, 2014.
  1. higginskatie
    higginskatie Member
    256
    Jul 13, 2013
    Or do you run a separate extension cord out to the power pole? I know the cords can get warm sometimes so I am thinking about the pup's electrical systems.
  2. friartuck
    friartuck Well-Known Member
    2,854
    104
    Nov 1, 2007
    Perry, MI
    I plug mine into the 20amp circuit usually used for the AC. In my other trailer that did not have AC I used the wall outlets with out any problems.
  3. Jayko
    Jayko Jayco 141J aka Big Bertha
    1,263
    Jul 10, 2012
    We do plug the in to the interior outlets.
  4. bondebond
    bondebond New Member
    2,079
    Aug 14, 2008
    I plug one heater into the single 120v circuit in the PUP that is not dedicated to the air conditioner. However, I frequently run two heaters, so I added a second 120v 15 amp circuit. I've done that in the last two PUPs with no problems. I also wanted an outlet in that part of the PUP that did not have 120v power nearby. The main breaker is still 30 amps. Without a second circuit, I would trip the breaker otherwise.
  5. nfisherman
    nfisherman Member
    320
    Apr 23, 2005
    Illinois
    Your PUP should have at least 15-amp circuits for the outlets and more for the A/C outlet. You shouldn't have a problem with a typical space heater.
  6. kitphantom
    11,753
    854
    We plug it into the pup's outlet with no problem. We don't run any other heat-producing appliances at the same time.
    In our previous pup, we ran a separate extension cord out a gap in the canvas, when we were camped in very cold weather (teens to upper 20s), so needed the space heater and the electric skillet at the same time. The Cobalt has a furnace, the space heater is just supplemental heat when we chose, so we have no problem unplugging it we take a toaster oven on a trip.
  7. Raycfe
    15,238
    1,449
    If we use an electric heater, we plug it into the air conditioner outlet.
  8. CREEPPINGCHARLIE
    CREEPPINGCHARLIE CAMPING RECHARGES THE HUMAN MIND
    623
    Nov 14, 2007
    I plug my space heater into the standard PUP outlet. No problems except when girlfriend forgets and plugs in hair curler. [8D] [PU] [PUT]
  9. ghacker
    ghacker Active Member
    3,438
    Nov 8, 2009
    Since we've got A/C, we've got the luxury of a 15a and a 20a circuit so we can one 2 heaters if necessary. With the Gizmos and the Reflectix mods, it can get pretty toasty. Seldom have had to use both.
  10. ve3tiz
    ve3tiz New Member
    32
    Mar 22, 2014
    We carry a 12/3 50 ft extension cord and plug it right into one of the 120v duplex outlets on the site's power pedestal.
  11. generok
    generok Well-Known Member
    2,488
    659
    Feb 7, 2013
    Anchorage, AK
    We plug right in to the PUP outlets. Haven't had a problem yet.
