Do you weather proof your power cord connections?
Discussion in 'Wiring' started by Wrenchgear, Jul 9, 2016.
  1. Wrenchgear
    3,245
    531
    Aug 5, 2010
    5 Star Eagle Camper
    I've been dry camping for 20+ years, and only recently have been getting set up on electrical sites. I'm heading to an electrical site later this summer that will have me set up quite some distance from the power post on the site. I'll probably be about 150 feet from the post. I have enough cords (10/3, no A/C) to stretch the distance to the post, but I'll be using 3 cords plugged together to do it. Does anyone try to protect their plug together connections from rain and such? I've never bothered before, but running power cords to my Pup is still new to me. Just asking what others do.
    I've heard of guys notching out a margarine container (or similar) on each side. They lay the connection in there and then snap the lid back on. The lid keeps the rain off the connection, and the rest of the container holds it up off the ground. Does anyone do that, or something similar?
  2. Ductape
    Ductape Well-Known Member
    1,105
    98
    Jun 12, 2013
    I have never bothered, but I might ensure my connections would have no chance of sitting in standing water in the event of rain. I would certainly see no harm in the plastic container trick, especially since it would be free.
  3. generok
    generok Well-Known Member
    2,482
    655
    Feb 7, 2013
    Anchorage, AK
    I've only had to run further than my PUP's shore power cord a few times, mostly because the sites were motorhome "pull in" sites, putting the power pole on the other side of the site for back in trailers.
    I thought about it, but all I really looked at was if the was a potential for water to puddle where the cords connected. Luckily I'm normally in a high gravel spot, so I didn't worry about it.
    In general, I don't worry about it for outside power for Christmas lights, gutter/roof heaters, engine block heaters, and the like. So, I'd probably not worry about it too much for my PUP (I don't run A/C either).
  4. frankvanw1
    frankvanw1 London, Ontario, Canada
    360
    Mar 18, 2009
    London, Ontario
    Wrenchgear,
    You are probably going to one of our nice provincial parks where the sites are big. The power post (outlets) is usually at the rear between two sites servicing the two sites. Depending on which site you are on it can be a ways to the RV. I have never done anything really and ran 30 amp cord and lied the connected cord on the grass and hoped for the best.
    Other than a margarine tub, a one liter or two liter soft drink (pop) bottle with the ends cut off could do the trick. This would make a little tunnel for the cord connection to go in and be protected some what.
    A margarine tub, yogurt tub, flower pot, etc. turned upside would make a little dome for protection.
    What others do? I do not know and maybe they can add here.
    A quick search and here is a commercial product I found: (there are others) dome cord connection protector
    Good luck and happy camping.
  5. WeRJuliIan
    907
    90
    May 15, 2014
    Sarasota, FL
    I'm surprised nobody mentioned duct tape...
    As long as they're well made, connectors are watertight, so you only have to worry about sealing the gap between them.
    I've used plastic sandwich bags, in the past.
  6. swordfish
    swordfish Well-Known Member
    2,209
    37
    Sep 27, 2010
    Yogurt container, ziplock container can also be used. If you want something fancy go power cord connector. For the 30-amp extension cord, go with containers or raise it up with a rock and cover it with a bucket.
  7. Customer
    Customer Well-Known Member
    2,436
    243
    Jun 5, 2014
    I notched the correct size Rubbermaid container and always carry it with us. I have used it a couple of times.
  8. Snow
    10,103
    1,027
    Never and I have used 100ft with 3 cords, never taped or rubbermaid any of the connections.. What I do is prop the connection up on a rock, piece of wood or something like that ...
  9. SmilinBeard
    SmilinBeard Member
    507
    Feb 18, 2008
    I keep mine plugged in with a 100 ft cord much of the time, and I do not weatherproof the connection between the power cord and the pup connection. No connectors are on the ground though. The few times I was at a site where I needed the extension to my 30 AMP line, I just let it sit on the ground. No problems.
  10. durhamcamper
    durhamcamper Active Member
    738
    191
    Apr 21, 2010
    Pickering, Ontario
    I also carry 3 50 ft 10/3 cables. I often need 2 and only once so far have I needed 3. I've never done anything where I join the cords together other than to make sure they are tight and not in a depression where a puddle could form.
