WHEELBURNS
- Feb 25, 2015
- 27
Subject says it all. The guy I bought in from says no, but the manual has vague setting listings that lead me to believe it does.
The manual lists:
Absorption mode: This is the normal operation mode. This mode provides the 12 Vdc and current to appliances, as well as slow charging.
Bulk mode: In this mode, the output voltage of the converter will switch to 14.4 Vdc range for a maximum of 4 hours.
Float mode: In this mode, the converter is charging the battery with a trickle voltage of 13.2 Vdc range. When the converter senses a demand, the converter automatically returns to the "absorption mode".
Nowhere does it tell me how to switch these modes. It doesn't say "bulk mode" charges but it would make sense that it does. This is a WFCO ULTRA III Power Center.
Any guidance would be appreciated. Too cold to just get out a fiddle with things.
The manual lists:
