Doing some maintenance today, how much oil in spring tubes?
Discussion in 'Lift Systems' started by bheff, Aug 26, 2019.
  1. bheff
    bheff Well-Known Member
    1,184
    628
    Feb 24, 2011
    NW Arkansas
    2011 Flagstass 625D with Goshen lift (electric winch) I replaced and sealed the electric fan, did some general cleaning and lubed the lift system from below and dry silicone lubed the lift arms. I need to pull the spring tubes and add some 30w but couldnt remember the correct amount. 10-20cc per tube??
    T.I.A.
  2. cabranch47
    cabranch47 Member
    78
    25
    Nov 29, 2016
    Hi, I dropped the tubes, covered the bottom weep holes with tape and used 120 wt. gear oil. Put it in with a horse syringe. Lots thicker and I felt it would last longer.
