Dometic 2193: Amazing on 120v, sucks on propane
theseus
Living the Darkside...
Silver Supporting Member
Feb 6, 2007
3,575
Centerville, OH
Just as a point of reference, the High/Med/Low switch should only change the size of the pilot light. This isn't an appliance that makes a massive flame.
Sinyk
Jul 8, 2015
88
The new Marshall Excelsior regulator installed just fine. Leak tested it and saw nothing bubbling out. This one does have a port on the side (i realize the old one had a port on the other side, but it was recessed with an Allan screw. This one is a hex nut).
I'm currently running the fridge on 120v to get it nice and cold, and i'm also monitoring the temperatures out the back on the fins as i'm going to do the fan mod. (right above the boiler, the temps were over 230F!) I happen to have a lot of low power silent pc fans (0.12A, 73cfm, 140mm, 0.3 sonne) that will work great off the 12v connector at the back of the fridge.
I should do the baffle mod too, but i'm having a hard time finding any good pictures of how-to's online of what people did. Anyone have some good posts to reference? Do I have to remove the fridge to install one or can you slip it around the fins? Any ideas on what material to use?
bupkis
Howdy!
7,965
N. TX
there is very little distance between the top and bottom vent for a good chimney effect. Long chimneys have better draft. This one seems simple, narrows the gap, directs air flow to the fins and makes a chimney. The sides (at top) could be closed off also forcing any convection to the fins. There is a (searchable "dometic fridge fan thermostat") thermostat disk to attach to the fin to turn a fan on/off. Others hopefully will supply the best on/off temp!
https://lh5.googleusercontent.com/-1pUxK7vukTY/TJlXGoUtwfI/AAAAAAAAAXA/lxTEHd2xCSc/s512/100_3578.JPG
additional info baffle
https://www.campingworld.com/on/dem...nuals/Refrigerator Vent Application Guide.pdf
Sinyk
Jul 8, 2015
88
I'll have to find a suitable material to make a baffle out of and i'll have to play around with fan positioning. With PC's the fan is usually directly on the heatsink, but i don't know if that would work the best in this application.
Arruba
932
Central Oregon
This is a discussion on fans/fan mods from another forum I follow:
If you go to Wander the West, where the above post came from, there are several discussions on it including some input from Four Wheel Campers themselves. At the time, and maybe still, FWC installed fridge fans at the factory.
Good luck.
bupkis
Howdy!
7,965
N. TX
"Fig. 2-2. When positive pressure is applied to one leg, the liquid is forced down in that leg and up in the other. The difference in height, "h," which is the sum of the readings above and below zero, indicates the pressure."
dwyer instruments
rob.mwpropane
367
dwyer instruments
Should add that you'd need a manometer that's good for propane, so at least 14wc needed. The most you can do with ^^ is 8wc.
If someone was going to do this DIY, I'd get one of these... just tap the gauge to really know where it "settles" as they can be a little sticky after adjustments. Added bonus is it comes with the fitting that'll work for 99% of regulators out there.
