Door Channel replacement parts?!??
Discussion in 'Miscellaneous Repairs & Maintenance' started by AaronWard, May 23, 2011.
  1. AaronWard
    AaronWard "Measuring is the key to a successful rebuild...."
    30
    May 19, 2011
    Hey all,
    I have a 1983 Coleman and one of the channels for the door is damaged. I need to replace it so the canvas can connect to the door. Any ideas where to buy a new channel?
    thanks,
    aaron
  2. jshulenberger
    jshulenberger New Member
    210
    Sep 29, 2010
  3. rj laney
    rj laney New Member
    55
    Jul 23, 2011
    i had the same or similar problem, it was a plastic molding on door frame i could not find any where but got lucky and the owner of a rv store who had a shop made some out of scrap sheet metal. they work better than the plastic ones ever did!
    all i did is give him a small piece of original and he made the neww ones. look for a a hvac shop that does ducting in your area and mabe u can talk them into makeing them for you. good luck, i know how fustrating it can be finding coleman parts.
  4. bigelmo
    bigelmo New Member
    40
    Jul 20, 2011
    Just so happens, that as I have been researching canvas replacements for the 88 Plantation, I noticed that
    Bear Creek Canvas says they have Coleman door channel. Hope this helps.
