Door issue
Discussion in 'General Camping Discussion Forum' started by Fred cook, Apr 9, 2017.
  1. Fred cook
    Fred cook Member
    37
    Mar 13, 2015
    Evansville indiana
    Morning, i have 2009 palimino yearling it seems my door does not want to fit correctly. Is it possible that i need to raise the camper a little further set the door then bring it back down to it? I have a hard time getting it into place when the guide wire is at full length. Its used pup so it may be possible that the wire as been shortened to. Any thoughts?
  2. BigRedTruck
    BigRedTruck Member
    428
    Jan 23, 2011
    Make sure your pup is completely level. If ours is not level, the door will not go in correctly.
  3. amberckaufman
    amberckaufman Member
    38
    Jul 24, 2015
    Wrightwood, ca
    This was the solution for me. I came here for help, and everyone figured it out for me! I (newbie) was using the stabilizer jacks as levels and tweaked the whole thing. Once I lowered it, leveled it, and used the stabilizer jacks properly, it shuts. Still will a little force, but like any camper door I've used.
  4. Fred cook
    Fred cook Member
    37
    Mar 13, 2015
    Evansville indiana
    No issue with door closing mine is actually getting it into the opening of the camper. Thanks for the info.
  5. 1380ken
    1380ken Well-Known Member
    2,045
    479
    Nov 7, 2013
    Mass
    Be careful if you remove the guide wire and lift higher. Stuff can break.
