Door storage track screw pulling out
Discussion in 'Miscellaneous Repairs & Maintenance' started by carguy4471, Mar 13, 2020.
  1. carguy4471
    carguy4471 Member
    82
    45
    Feb 10, 2020
    Hastings, MN
    In my new pop up, one screw in the door storage track (screwed to ceiling) is stripped and pulling out.
    Rather than drop it off @ the dealer to have to wait to get it fixed, how would folks fix this?? Abandon the hole and reinstall the screw nearby or put something in the hold to affix the screw??
    Any thoughts would be great!!
    Thanks!!
  2. BikeNFish
    BikeNFish Well-Known Member
    3,440
    2,324
    Apr 24, 2017
    Maplewood, MN
    I would first assess why the screw came out. If it came out because there was no backing wood behind it, I would find a new place to drill a hole. If it came out because it stripped out, I would try to use the same hole by inserting some toothpicks and wood glue into it and re-insert the screw.
  3. carguy4471
    carguy4471 Member
    82
    45
    Feb 10, 2020
    Hastings, MN
    I know that it's stripped, but I'm unsure if there is anything behind it. The hole is pretty small to try to see into. I could use a pick and probe in there a bit to find out next time I have the pop up setup.
  4. BikeNFish
    3,440
    2,324
    Apr 24, 2017
    Maplewood, MN
    I've used the toothpick method on door hinges in my home and on my pup's under-the-sink access door and it works pretty well.
  5. carguy4471
    carguy4471 Member
    82
    45
    Feb 10, 2020
    Hastings, MN
    That's pretty ingenious to be frank. I would have never thought of it.
  6. bheff
    bheff Well-Known Member
    1,504
    918
    Feb 24, 2011
    NW Arkansas
    One of the oldest tricks in the books. I'm a huge fan of epoxy but it can be tricky working with it overhead. Toothpicks and wood glue would be much easier. (And cheaper)
  7. WrkrBee
    WrkrBee Well-Known Member
    3,875
    1,686
    You would be surprised at how many things have been repaired with toothpicks (matchsticks for larger holes) and wood glue. It's an old trade trick that's been around for years.
  8. theseus
    theseus Centerville, OH
    2,896
    439
    Feb 6, 2007
    Centerville, OH
    Use a rivet. I had to do this with my Palomino.
  9. IndyRick
    IndyRick Member
    90
    63
    Mar 7, 2019
    Indianapolis, IN
    Put epoxy putty (Quickwood is a common brand) in the hole, and let it cure about an hour. Drill a pilot hole for the screw, and reinstall. You are then welcome to put some fresh epoxy putty between the track and ceiling and you'll have additional holding power for the track.
