Here is how I drained and cleaned out my Suburban Hot Water Tank... I was surprised what came out...
I have a 2007 Niagara and a minimally used hot water heater, I figured with little use little junk in it, WAS I WRONG... (I was told the first owners did not like a popup and sold it the first year and the second owners used it for 25 outings and rarely used the hot water tank. So I prove that sitting is as bad as using, maybe worse)
First, here is the water heater showing the drain plug.
IMAG0244a by Fleetwood Tim, on Flickr
Drain plug by Fleetwood Tim, on Flickr
This picture shows the safety release valve in the open position, by moving it 90 degrees.
IMAG0246a by Fleetwood Tim, on Flickr
I needed a 27mm Metric or a 1-1/16 SAE and found them both on a 4 way tire iron. The tire iron made for easy removal.
I sprayed into the whole with a stream of water from the hose and I drained and flushed until no more lime came out.
IMAG0249a by Fleetwood Tim, on Flickr
IMAG0251a by Fleetwood Tim, on Flickr
I removed about 3 cups of lime deposits from the water heater by flushing. I was shocked at how much lime was in there.
I was also shocked to see how eaten the Anode rod was
IMAG0250a by Fleetwood Tim, on Flickr
Here is the replacement recommendations from Suburban.
Suburban 232768 Aluminum Anode Rod by Fleetwood Tim, on Flickr
I put the used Anode Rod back in until I could get a new one bought as it is a holiday today.
I prefer not to think about drinking this water.
My next MOD will be a whole house filtration system for under $25 dollars that will filter down to 10 microns.
