Drain from sink not draining
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by Milehifireguy, Jun 15, 2015.
  1. Milehifireguy
    Milehifireguy New Member
    Jun 2, 2015
    So hand pump works but sink isn't draining. Is it safe to use drank or a hand roto rooter on it? Bottom drain is open as well, no grey/black water tank. Thanks!
  2. chefaleslie
    chefaleslie Always looking for a great MOD
    295
    26
    Feb 9, 2013
    Sisters, OR
    In my pup the drain was a very thin flex pipe. I would not use a snake. But there might be a kink in the pipe when you swing down the galley.
  3. scrt95019
    scrt95019 Member
    233
    18
    Apr 16, 2015
    whatever you do... DO NOT use an air compressor to try and blow it out... mine blew off when i did that [LOL] [LOL] [LOL]
  4. 3hooligans
    3hooligans Member
    622
    Jul 27, 2014
    Boston
    By saying bottom drain I assume you did open the cap on the outside of the pup and not the low point drains?
    Also can you see the drain hose? Is it clear? Can you see a blockage? And lastly is there a strainer in the sink bowl?
    Me the missus and three hooligans
    2014 rockwood premier 2317g
    2012 F 150 super crew Eco boost.
  5. Dubbya
    6,130
    53
    Aug 2, 2011
    Steinbach, MB
    Flip the galley over, remove the pee trap and clean it. They tend to get gummed up with toothpaste, food particles and miscellaneous scum over time.
