Drawer Storage
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by Sokokis, Jul 23, 2013.
  1. Sokokis
    Sokokis New Member
    29
    Feb 18, 2012
    I'm thinking of trying to convert the storage under the dinette benches and the "couch" into drawers instead of just using the "shove and store" method. Any thoughts? I realize I'll lose a bit of storage space, but it is such a PIA to get anything out that I think it might be worth it.
  2. jrclocks
    jrclocks Member
    585
    Jun 24, 2008
    Our PUP came with a drawer under one of the benches.
    Very convenient.
    JR
  3. Seven
    Seven New Member
    Mar 2, 2011
    I have been thinking about this alot myself. One of my challenegs is the storage of all of our stuff. Food , Clothes, ect, ect.
  4. 94-D2
    94-D2 Happy Campin'
    2,281
    140
    May 21, 2010
    Sutter Creek CA
    I have one under dinette seat. Use it all the time.
  5. ghacker
    ghacker Active Member
    3,438
    Nov 8, 2009
    I went the other direction, converting a drawer under the sofa to a cabinet drawer and gaining quite a bit of space. We keep seldom used items under the sofa and put the few things we do use with some frequency (kitchen stuff) on the shelving over the sink/stove so it only gets moved once/trip.
    Storage on a PUP is at such a premium that I thought it just works better that way but whatever works best for you.
  6. SteveM_CT
    SteveM_CT Member
    251
    Jun 12, 2012
    The drawer will result in less space. The drawer has to be smaller than the space, as there's always room on the sides, top and bottom, including room for the slides.
    You may be better off with drawers, though, if the space isn't very usable.
    I have a space under the sink/stove that has a small door with a large space behind it that I really can't use, so a drawer may be more useful. There's also a large unused area under the stove that I'm thinking of adding a drawer to. A large vertical spacer between the cabinet and the bench might get a door so that I can store large flat things (e.g. cutting board).
    One thing you could do is to get some storage boxes that are good at filling the space. Then you don't have everything piled in one heap.
    Creativity is always good.
    Steve
  7. nimrod65
    nimrod65 Member
    545
    Jan 31, 2011
    I like the idea of installing a door under the storage bench. Makes it easier to get at stuff while the bed is made up. And then put things in plastic storage containers to keep them sorted and contained.
  8. Raycfe
    17,257
    2,854
    I took our drawer out also, you do lose space. The factory cheap plastic guide are just that... cheap. And if you happen to leave a drawer open and the kids jump on it....good by drawer. Did add doors to the dinette ends, that works nice.
  9. The Postman
    The Postman You gotta love Camping!!
    462
    Jul 20, 2009
    Wishing I was at Waskesieu!!
    We use the small green plastic bins from WalMart inside our under seat cupboards. We have used that and Sterilite drawers for a few years now, and it all works just fine.
  10. beemerboy
    beemerboy New Member
    659
    Feb 13, 2009
    North East Connecticut
    This what I did inside one of my dinette benches:
  11. blackbear
    blackbear We want to do this for a living !!!
    290
    Jul 19, 2012
    ^^^That is maximizing space [:D]. Well done camper [{:)]
  12. Familyman68
    Familyman68 test
    17
    Jul 17, 2012
    That looks awsome... I've found my next project, didn't think about dividers... but sure makes finding things easier and you can pack them a little higher .... Love it THANKS!!!!
  13. Jayko
    Jayko Jayco 141J aka Big Bertha
    1,263
    19
    Jul 10, 2012
    Have you considered a sliding tray? In essence, a sliding floor?
  14. johnbender2013
    johnbender2013 New Member
    Mar 27, 2013
    I like the idea of the dividers as well! Did you make the dividers yourself or did you get them from a retailer?
  15. beemerboy
    659
    Feb 13, 2009
    I cut 1/4" plywood and painted it white and held together with angle brackets. I had the plywood and brackets left over from a previous project so all I needed was the paint. This probably would cost less than ten bucks to do.
    If you notice, I made the two dividers low enough so I can store my CI pans on top. I also made a notch in the left panel to hold my small broom.
    I found that this helps to keep things organized.
  16. Srt4inliny
    Srt4inliny "It ain't campin if ya can't hear nature"
    123
    May 18, 2011
    We did the same thing the old drawer was a little warped and was a little hard to open so I removed the face of the drawer and removed the slide mechanism and placed the face back on under the sofa. we have about three inches of room on each side added to the storage.
  17. chinolofus
    chinolofus New Member
    349
    Apr 27, 2012
    i just take the lid off on the bench and then stuff pillows around the sides and top of the drawer. i always use the pillows when we camp so the drawer is fully functional when camping. if you do it like that you really arent losing much space at all. maybe a half inch of width and half inch of depth.
