Drying ceiling
Discussion in 'Camper Restoration Projects' started by Heilman_5, Sep 28, 2017.
  1. Heilman_5
    Heilman_5 New Member
    23
    Sep 25, 2017
    I pulled down the "wood" from the ceiling. Is there a way to dry out the Styrofoam insulation?
  2. TRR
    TRR Active Member
    453
    224
    Nov 3, 2014
    Alabama USA
    How saturated is it?
    Having it parked outside on a hot day (or two, or three, or ...) with the windows all opened and some strong fans inside blowing up at the ceiling might get 'er done.
    But if the foam is saturated, you might have to replace that too.
  3. Heilman_5
    23
    Sep 25, 2017
    If I push my finger into the styrofoam I get water
  4. chambo
    chambo Active Member
    358
    114
    Apr 27, 2015
    Southern California
    sounds like it is going to take a while. Is the outer layer of the ceiling still intact? That is going to really slow down the drying process.
  5. Heilman_5
    23
    Sep 25, 2017
    No I took the ceiling down, the paper board, and white paper ceiling
  6. TRR
    TRR Active Member
    453
    224
    Nov 3, 2014
    Alabama USA
    If you're impatient, depending on how stable the styrofoam is, you might try a wet-dry vac to suck as much water out of it as possible. But you stand a real chance of sucking it right off the ceiling.
    I think with enough air flow, temperature (warmer being better), and time the styrofoam should dry out. You might ask a place that does water damage remediation in homes for suggestions.
