Dual hitch adapter
Discussion in 'Cargo Carriers / Bike Racks / Other Storage Option' started by Ourkid2000, Aug 14, 2019.
  1. Ourkid2000
    Ourkid2000 New Member
    21
    Aug 14, 2018
    Nova Scotia
    How's everyone feel about the dual hitch adapter that has an extra 2" receiver for adding something like a hitch mounted 2-3 bike rack? Doesn't seem to be too much of an extension over a regular one. Seems ideal to me but your input is appreciated.
    Something like this:
    https://www.curtmfg.com/part/45810
  2. the-one1
    the-one1 Member
    65
    53
    Apr 6, 2016
    It'll decrease your tongue weight limit. Also, you can't have the bike rack on while hitching up the trailer. The locking lever gets in the way. You'll have to hitch up the trailer first and then slide in the bike rack.
  3. mpking
    mpking Well-Known Member
    1,439
    406
    Jun 17, 2014
    Raynham, MA
    @the-one1 Never noticed that before, but it's pretty clear in the promotional photo:
  4. the-one1
    the-one1 Member
    65
    53
    Apr 6, 2016
    If you have ground clearance, you can get this from harbor freight and use a lower drop receiver. But you'll still be limited by tongue weight. I have this below, I could not hitch up the camper with the bike rack on, the trailer lock got in the way and I could not go with a lower receiver due to ground clearance.
  5. eoleson1
    eoleson1 Well-Known Member Gold Supporting Member
    3,140
    1,303
    Jul 5, 2011
    Macomb County Michigan
    I used one with my starflyer. It worked well. Made the truck squat more, but I never had any clearance issues and it didnt cause the trailer to sway.
  6. Ourkid2000
    21
    Aug 14, 2018
    Nova Scotia
    How do you determine the tounge weight?
  7. Aladin Sane
    1,132
    153
    Jul 3, 2008
    Iowa
    We used the HF version with our old lighter Viking pup. I would not use it with the Starcraft HW we currently pull. It has about 400 lb of tounge weight, and extending that out another foot or so would put a lot of strain on the hitch if you ask me.
    WVhillbilly likes this.
  8. Snow
    11,064
    1,704
    Many of these extenders and dual hitches reduse the tow rating and tongue weight rating of the vehicles receiver by as much as 50 %. ..
  9. Rusty2192
    Rusty2192 Well-Known Member
    1,040
    464
    Jul 30, 2014
    Kentucky
    I wouldn’t use one of these adapters with a Santa Fe. With a full-size truck they may be viable, but it would add too much weight and leverage for most mid-size unibody SUVs.
    I used one with my old F-150 and tiny Apache Raven (500 lbs) and even that showed how much it magnifies the load. I personally wouldn’t use it again with any smaller TV or larger pup.
  10. lksdrinker
    lksdrinker Active Member
    210
    54
    Oct 15, 2018
    rescamilla and WVhillbilly like this.
  11. Ourkid2000
    21
    Aug 14, 2018
    Nova Scotia
  12. bheff
    bheff Well-Known Member
    1,504
    922
    Feb 24, 2011
    NW Arkansas
    I'm kind of a bike snob and wouldn't trust any of my bikes on that clamp on style. Will it work? Maybe, would I trust it? Nope. When I'm not pulling the pup I have a 1up bike rack in the receiver. If I'm towing the pup, the bikes get put on crossbars on the roof.
  13. wayoutwest
    wayoutwest Member
    102
    Aug 23, 2013
    Oregon
    Truth, I need to hitch up the camper, then put the bike rack on.... still didnt work as the Yakima bike rack (4bikes) is too long (deep) and the bikes end up hitting the propane tanks and camper roof....
  14. TravelingAggie
    TravelingAggie Member
    70
    30
    Sep 22, 2019
    South Central PA
    Since this option, When added to a PUP, would sit higher than the campers roof, are you worried about reduction in gas mileage or towing difficulties from wind resistance hitting the bikes?
  15. lksdrinker
    210
    54
    Oct 15, 2018
    I use the bike bunk along with a cargo platform and a wheel chock style bike carrier for 2 bicycles. So my setup is not quite as tall as what I posted in the photo. But, yes they sit higher than the roof of the camper. Am I worried about the reduction in gas mileage? Not really. I'm sure the extra drag is not helping my gas mileage, but the family considers the bicycles an integral part of camping. So they come every trip and this is the best/easiest/quickest/safest setup I've been able to make work with what we've got. There are enough "holes" that the bikes dont really act like a sail. I bet its only a little less fuel efficient than having the bikes sitting on a roof rack on top of the pup which is quite common. A bigger concern with this setup really should be tongue weight. Everything adds up pretty quick and the bike bunk plus the cargo rack plus the bicycles probably adds close to 100 lbs if not more.
    edit:
    Here are some pics from the last trip out....learned that the bike bunk also made a relatively simple spot to strap the new grey water tank to as well!
  16. Finch
    Finch Member
    43
    May 12, 2018
    I am interested in adding a bike bunk to our PUP. From what I can tell, do you have to completely remove the bike bunk by unbolting the 4 bolts per side in order to pull out the PUP bed? Is there a quick disconnect per se? It would be ideal to arrive at the camp site, unload the bikes, and quickly remove the bike bunk, and continue setting up the PUP. Anyone know?
