Electric brake system
Discussion in 'Tires / Brakes / Bearings / Axles' started by DESERTFOX, Apr 22, 2009.
  1. DESERTFOX
    DESERTFOX New Member
    Apr 20, 2009
    How do you adjust the electric brake system? I'm n2pup owner and felt very stress bringing that new pup home since it feels like whenever I tried to stop I feel that the camper's wheels are screeching, and I thud in my back whenever I pump on that brake pedal. Is my electric brake set to hard since whenever I put the brakes on it seems like I have to slow way ahead of time and give too much space between me and the vehicle in front of me.
    Please Advice.
    Thanks
    DESERTFOX
    Ford Explorer EB '03
    Fleetwood UTAH '07
    So done with tent camping...
  2. cksteele
    cksteele now where did i put that hot dog
    274
    Sep 3, 2008
    bristol ct usa
    If the brakes are screching you might be locking up the tires wich means you have them set a bit to high. You should be able to feel the brakes working but they should not be set so hight that they are stoping the trailer and the tow vehicle. The thud sounds like you may need to adjust the brakes at the wheels. They are adjusted simularly as a set of drum brakes on your car. Good luck and welcome to the portal.
    chuck
    2008 palimino stampede hybrid
    2005 chevy silverado
  3. theseus
    theseus Centerville, OH
    2,896
    441
    Feb 6, 2007
    Centerville, OH
    Also I would wager good money that you are using a time-delayed brake controller like a draw-tite. If you used a proportional brake controller like a Tekonsha Prodigy or P3, you wouldn't notice the braking behind you. It would feel more like you were braking just the car.
    Bruce ______________
    2004 Expedition & 2000 Palomino Mustang SL-SG-FT
    http://www.thecampingchild.com
  4. John L
    John L New Member
    520
    Aug 15, 2006
    Vermont
    I have a Hayes endeavor controller and there are adjustments you can make at the controller itself that has to do with the weight of the trailer. then you can go from there and adjust the power up or down accordingly.
    John & Kitty (Empty Nesters)<img src=../Images/icons/icon_smile_camping.gif border=0 align=middle alt="Camping">
    '02 Coleman Cottonwood <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle alt="PopUp">
    '97 Silverado X-Cab Stepside <img src=../Images/icons/icon_smile_suv.gif border=0 align=middle alt="Tow Vehicle">
  5. theseus
    2,896
    441
    Feb 6, 2007
    Centerville, OH
    All brake controllers have adjustments that can be made. However a proportional controller takes into account your deceleration and applies just the enough braking to the trailer. The Hayes Endeavor looks similar to a Tekonsha Primus, which is proportional.
    Time-delayed controllers apply 100% of what ever voltage you set to the brakes after a set amount of time. This causes a lot of extra wear on the trailer brakes and a lot of banging around. It also provides less control in a braking situation.
    Edited by - theseus on April 23 2009 06:36:27
