electric lift - will only raise halfway on a full battery?
Discussion in 'Lift Systems' started by PUPnoob5, Jun 13, 2019.
  1. LivinLife
    LivinLife New Member
    Jun 26, 2019
    TX
    I haven't read anything reflecting a manual override on my electric winch which I love. I will definitely check for this on my lift because I would NOT want to get stuck if my electric lift dies. Thanks for the good information.
  2. Grandpa Don
    Grandpa Don Active Member
    414
    178
    Sep 5, 2018
    I'd like to see a picture of your winch. Can you upload one?
  3. LivinLife
    Jun 26, 2019
    TX
    Hi! I can snap and upload a picture tomorrow. I've taken the PUP out 3 times since buying it without incident. Now, it's not lifting up all the way. The cable becomes taut as if the roof is fully extended. I added some spray lubricant underneath, on the wench, cables, and telescoping braces. I need to find some grease. Any suggestions? I finally was able to get it to lift from initial 4 inches to a total of 7 1/2" inches before darkness set it. It continues to stop, though, so I suspect it hasn't been greased in a while. Any assistance you can provide will be appreciated.
  4. bheff
    bheff Well-Known Member
    1,185
    629
    Feb 24, 2011
    NW Arkansas
    I'll be interested in what you find out is causing the issue.
  5. LivinLife
    Jun 26, 2019
    TX
  6. LivinLife
    Jun 26, 2019
    TX
    So - I’m finally back in town and worked on the lift again. More spray layers on the winch teeth, cable, and telescoping poles and the camper lifts to 11 1/2”. This is a very slow process. Is this normal? The cable remains taut each time it stops lifting. I hate to take it out for the weekend because I’m afraid the cable is catching on a pulley. Pic is too large to upload..
