Electric Tongue Jack- Broke the manual attachment
Discussion in 'Stabilizing Your Camper' started by silverfz, Sep 5, 2019.
  1. silverfz
    silverfz Active Member
    739
    57
    Aug 8, 2013
    My battery was on its way out and i used an impact wrench on the manual twisting part and broke it
    Called the LCI tongue company and they told me to get a new unit.
    the tongue works fine and i am now worried about what if...any one faced this challange
    The 3/4 Socket of soft metal on top of the manual end cracked off.
  2. WrkrBee
    WrkrBee Well-Known Member
    2,245
    846
    Pictures would help. Can the "socket" be welded back on?
  3. bheff
    bheff Well-Known Member
    649
    256
    Feb 24, 2011
    NW Arkansas
    Using an Impact was a bad choice. A simple drill will work without bashing the attachments and gearing.
    If your camper battery was dead you can always use jumper cables and get power to it from the tow vehicle, or supply it with 12 volts and a 7 wire plug.
    P.s. Harbor freight has them cheap
  4. joet
    4,508
    841
    Never saw one that was hard to crank. We crank them on the lot all the time.
    kcsa75 likes this.
  5. xxxapache
    2,813
    803
    I would put a socket on the metal that's left and spot weld it through the hole where the ratchet drive attaches.
