Electrical installation question
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by Stamourowl, Jun 5, 2019.
  1. Stamourowl
    Stamourowl If it involves dogs and hiking count me in.
    113
    Sep 25, 2009
    I want to add a USB and cigarette charger to my popup. I’ve figured out how to wire it but I am unclear how to tap into another 12 volt line. I have way access to this line going to the carbon monoxide detector. Can I just add another wire to the yellow wire connectors?
  2. tombiasi
    5,157
    880
    There is 12 volts there. Sometimes the detector is on a smaller fuse. You will only be able to take from your new ports up to the fuse rating including the use by the detector.
  3. McFlyfi
    McFlyfi Active Member
    369
    150
    Aug 1, 2014
    Thousand Oaks CA
    Do you have any unused 12vdc slots on your converter/power distribution center?
    I have found it's easier to run brand new circuits- especially for trouble shooting later. You also don't have to worry about screwing up an existing circuit, again making troubleshooting later
    On my older pup, I added a fuse block wired directly to the battery for 6 brand new fused slots:
    http://www.popupportal.com/threads/list-of-mods-performed-by-rookie-huge-thanks.90616/
    On my Niagara, there were 4 empty slots on the power distribution center.
  4. Stamourowl
    113
    Sep 25, 2009
    [QsUOTE="McFlyfi, post: 1280119, member: 64359"]Do you have any unused 12vdc slots on your converter/power distribution center?
    On my Niagara, there were 4 empty slots on the power distribution center.[/QUOTE]
    Ummm total newbie here . How do I tell if I have empty slots? It’s a 1997 Dutchman. There are 2 fuses so 2 circuits currently.
  5. McFlyfi
    369
    150
    Aug 1, 2014
    Thousand Oaks CA
    The fuses reside in a "holder". The fuse allows the current to flow between the contacts across the fuse, delivering electricity to the device.
    Is there another "holder" either above or below either of the two fuses? In other words, a place to put a fuse into that has no fuse in it?
    If so, then you have room to add a new circuit (the slot where the fuse goes).
    Stamourowl likes this.
  6. BigAl
    BigAl Member
    57
    49
    May 22, 2019
    Wisconsin
    Just added a USB and cigarette charger to my 2000 Dutchmen last weekend. The detector in mine is on a dedicated circuit with a 2A fuse, so I tied into a different circuit. I have 4 circuits, all used - the CO detector, the furnace, the lights, and the battery charger.
    Check the fuse sizes first and see what's tied into what to determine where you have excess amps to draw on.
  7. rabird
    6,584
    258
    TX
    yes until you get too many wires for the size of 'wire nut', they make bigger ones if needed.
  8. Stamourowl
    113
    Sep 25, 2009
    Thank you! No empty fuse slots so I traced down the circuits to get it on a circuit with enough amps!
  9. Stamourowl
    113
    Sep 25, 2009
    I’ll only have 3 wires, but I will keep that in mind. Thanks!
  10. tombiasi
    5,157
    880
    You also need to watch the current draw on the circuit.
    FYI: wire nuts are not approved for mobile installations. You will find them in the AC junction boxes and elsewhere. If you use them tape them. Wrap the tape in the same direction that you tighten the wire nut. Before you ask, yes, I have used them.
  11. Toedtoes
    Toedtoes Well-Known Member
    1,534
    1,168
    May 28, 2018
  12. Stamourowl
    113
    Sep 25, 2009
    Rabird, can you explain or refer me to a page about your solar controller. That is one of my next purchases and I spied your signature. It has piqued my curiosity. :- )
  13. Stamourowl
    113
    Sep 25, 2009
  14. Stamourowl
    113
    Sep 25, 2009
    Thanks! Will tape. Under my seat, near the converter is currently a sea of wire nuts, at least 8 of them. I didn’t add them, but I might tape them all. :- )
    Also, how do I figure out current draw on the system? Totally number of devices using the 12 volt at once?
  15. tombiasi
    5,157
    880
    The sum current draw of each device on the circuit. If the device has the current draw printed on it use that otherwise you can measure it.
  16. rabird
    6,584
    258
    TX
    common and easy for PU builders to install. worse are those little blue things that pierce the wires!
    Comet solar charge controller
  17. roybraddy
    roybraddy Well-Known Member
    2,124
    736
    Mar 23, 2016
    King George, Virginia
    I am always adding things like this so I picked up one of those BLUE SEA SUB PANELS from Amazon... Looks like this... I am not a fan of taping into another 12VDC circuit to use for things...
    Google image...
    Now I have multiple 12VDC FUSED circuits for future things...
    I too have installed two of those 12VDC charge stations in my POPUP. One on each end... After I got these I wish I had got a different model that had a ON-OFF switch on it... The DC VOLTMETER turns out to be very bright... Even for a night light haha... I had to put clear tape over the display to darken it somewhat...
    The beautify of these BLUE SEA panels that have the round units can mounted vertical or horizonal. The round components can be rotated...
    Google image
    I find that AMAZON carries all of these type of panels and just about everything else I end up using in my trailer... AMAZON and LOWES haha...
    Also having a DC VOLTMETER on the panel is a great idea to keep you informed of your battery charge state when camping off grid... When it drops down to 12.0VDC then you will be close to the 50% charge state and you should stop using the batteries until they recharged back up to their 90% charge state otherwise you will start doing internal damage to your batteries...
    Roy Ken
    Anthony Hitchings and Stamourowl like this.
  18. McFlyfi
    369
    150
    Aug 1, 2014
    Thousand Oaks CA
    The DC subpanel (above) is an excellent way to do it. I did this in my first trailer. Ran 8g wire directly from the battery to the sub panel. Then had 5 separate branch circuits from that panel to power two 12v plugs, 2 USB chargers, and the digital thermostat.
    It makes it easy to troubleshoot too- if the device goes bad, you know what wire it is. Both of the 12v plugs eventually went bad, and I didn't have to spend hours troubleshooting it.
  19. Stamourowl
    113
    Sep 25, 2009
    This is exactly what I am installing.one of the panels with a voltmeter, cig lighter, and USB’s. I might go the sub panel route in the future, if I need more items. They are pretty neat.
  20. Stamourowl
    113
    Sep 25, 2009
    Thank you!
