Emergency breakaway cable
Discussion in 'Road Safety Systems' started by Matt T, Aug 10, 2019.
  1. Matt T
    Matt T Member
    56
    27
    May 7, 2019
    I need to pick up a new emergency breakaway cable and switch, are they trailer specific or pretty generic? I was thinking about getting the entire apparatus(like the picture) just to make it easier
  2. SteveP
    SteveP Well-Known Member
    1,528
    421
    Sjm9911, PopUpSteve and Matt T like this.
  3. roybraddy
    roybraddy Well-Known Member
    2,216
    783
    Mar 23, 2016
    King George, Virginia
    I got all I needed from ETRAILER...
    I got the coiled up version with a D-RING...
    Google image
    This may not work for everyone but in my case we are always off-road a lot and pulling our POPUP through underbrush sometimes...
    Works good for me...
    Roy Ken
    megcabra likes this.
  4. nineoaks2004
    7,382
    3,141
    Dukes, Fl
    I go tthe same set up at Tractor Supply works good
  5. nineoaks2004
    7,382
    3,141
    Dukes, Fl
    If you want to change the whole switch out, Rural King has the set up for a decent price.
  6. megcabra
    megcabra Well-Known Member
    1,915
    480
    Aug 12, 2015
    Chapel Hill, North Carolina
    I too have been pleased with the coiled version.
  7. lksdrinker
    lksdrinker Active Member
    202
    50
    Oct 15, 2018
    Which size did you both go with? I just returned the 4 footer for the 6 but haven't yet used it. I'm surprised there wasn't even longer ones available.
  8. nineoaks2004
    7,382
    3,141
    Dukes, Fl
    I got a coiled up wire from Tractor supply, it stretches and will not rub on the ground.
  9. megcabra
    1,915
    480
    Aug 12, 2015
    Ours is about 4” and seems long enough for our hitch.
  10. Camper054
    Camper054 Active Member
    144
    61
    Jul 23, 2019
    Indiana
    Thanks to OP and others who responded. Being a 'newbie', there is so much to 'learn'! We got a pop up this summer and the breakaway switch looks 'worn-out', which you would expect on a 19 year old camper. I was thinking if it works or not and how to test it and was searching this forum, when this thread came up in the results. Now I know, it is probably easier to just replace the switch than to see if it works?
    Thanks again.
  11. WrkrBee
    WrkrBee Well-Known Member
    2,576
    986
    Just pull the pin, that the cable is attached to, to see if it works and applies your brakes.
  12. ezakoske
    ezakoske Active Member
    525
    74
    Nov 30, 2014
    Escondido, CA
    My pin broke shortly after I bought the camper and was testing the emergency brake. I just replaced the pin and tether, not the entire switch.
  13. Camper054
    144
    61
    Jul 23, 2019
    Indiana
    @WrkrBee, hi, yes, I tried to pull the pin, but it is rusted and looks or feels to me need a stronger pull (which is what is needed, I am sure). And also, I wasn't/am not sure if by pulling the pin would make the switch 'break', and how to 'repair' it. Meaning, I am/was thinking that this is a one time thing - for emergencies only - and I would need to install another pin/switch/system :(.
    @ezakoske, thanks for your response as well. I am not sure how to replace the pin and the tether, probably, I just need to 'play' with it to see how I can do it :).
    Thanks all so MUCH!
  14. WrkrBee
    2,576
    986
    You want a good break away switch. If your's is in bad shape, replace it. You want to be able to pull it out to check the brake system and you sure want it to work in an emergency.
    Camper054 likes this.
  15. Camper054
    144
    61
    Jul 23, 2019
    Indiana
    Thanks and I agree. One more thing added to my 'do list' coming spring :). Just one more thing - I should be able to put it back after pulling it out to check, right?
  16. WrkrBee
    2,576
    986
    Yes.
  17. Camper054
    144
    61
    Jul 23, 2019
    Indiana
    Great, A million thanks, @WrkrBee !
  18. ezakoske
    525
    74
    Nov 30, 2014
    Escondido, CA
    Have something like this available as a replacement.
    https://www.etrailer.com/Accessories-and-Parts/Tekonsha/2010-A.html
    Or, just replace the entire unit and start fresh...
    You should be able to push the pin back in to disengage the brakes....
