Empty fresh water tank?
Discussion in 'Camper Storage / Winterizing & De-Winterizing' started by RhythmScience, Nov 7, 2020.
  1. RhythmScience
    RhythmScience Member
    64
    32
    Jul 26, 2020
    Hagerstown, MD USA
    I'm getting ready to winterize my NTU 2013 Palomino Y-series 4127 for the first time and I have a question about the fresh water tank. It sits below the floor of the camper, just behind the axle. I've emptied it as best I can (tilted the camper back and to the side with the BAL leveler), but it bulges down in the middle and won't drain all the way. I put a bottle jack below and pushed up a bit to get more water out, but there's at least a half-gallon of water still in there. Do I need to worry about draining the tank dry, or will it be okay for a little water to be in there over the winter? Should I pour in some RV antifreeze to mix with the remaining water?
  2. kcsa75
    5,267
    3,301
    Sep 9, 2013
    Kansas City
    You should be OK. If it does freeze, there is plenty of room for expansion.
  3. Arruba
    Arruba Well-Known Member Gold Supporting Member
    713
    374
    Nov 28, 2014
    Central Oregon
    You’ll be good in the tank for the reason mentioned above. As for adding RV antifreeze to the tank, I wouldn’t because in my experience, it takes more effort than you think it should to get it all out. That said, it depends on the ability get the rest of your plumbing drained. If it doesn’t drain well, then a gallon or two in the tank and cycled through the plumbing is probably warranted, keeping in mind my statement above.
    Good luck.
  4. RhythmScience
    64
    32
    Jul 26, 2020
    Hagerstown, MD USA
    Thanks! I won't sweat that last bit of water. I finally found my water pump and got RV antifreeze in all the lines. I think she's just about ready for the long winter.
  5. gladecreekwy
    1,561
    2,407
    Sep 25, 2016
    Jackson Wyoming
    Your good. Can’t ever get it all out.
