Engine Oil Cooler?
Discussion in 'Tow Vehicles, Hitch & Towing' started by Ian1357, Jan 5, 2017.
  1. Ian1357
    Ian1357 Member
    45
    Jan 4, 2017
    I have a bravada 2003. With which I intend to pull a pop up ( still looking). The ones I am looking at are about 3000LB Max weight. I intend to fit a transmission cooler. Do I need to fit an oil cooler as well?
    I have posted this similar question on other forums.
    Cheers
    Ian
  2. terry1419
    terry1419 Active Member
    669
    82
    Mar 6, 2016
    Streator, IL
    Not likely, especially pulling in flatland areas. Most popups pull pretty easily. Which engine do, you have? What answers have you gotten from the other forums? BTW, welcome to this forum from N. central Illinois.
  3. Novarich
    Novarich Active Member
    381
    42
    Dec 8, 2014
    I would. It's cheep insurance.
  4. Yak
    Yak Well-Known Member
    1,205
    89
    Apr 18, 2009
    Just worry about coolant temp, if the cooling system does it's job the engine oil will be ok
  5. generok
    generok Well-Known Member
    2,845
    1,177
    Feb 7, 2013
    Anchorage, AK
    Personally, I wouldn't bother unless you develop a specific issue while towing. Do you have a coolant temp gauge? I'd invest in a cheap Bluetooth OBDII scanner and monitor all the sensor outputs (with a smart phone) before I invested in an oil cooler.
  6. HiFiDave
    HiFiDave Singin round the campfire
    1,069
    Feb 1, 2012
    Exactly...if anything, get a higher core count radiator.
  7. Ian1357
    Ian1357 Member
    45
    Jan 4, 2017
    Thank you, I was not aware these existed. I will invest in one.
    Cheers
    Ian
  8. fix_it
    fix_it Member
    595
    Aug 29, 2010
    Many Bravadas had oil coolers from the factory. Look at the radiator. Aside from the radiator hoses, there will be two lines hooked to on end of the radiator (I think passenger side). These are for the transmission. If there is another set of lines on the other end of the radiator, then you have an oil cooler already.
  9. Ian1357
    Ian1357 Member
    45
    Jan 4, 2017
    Thank you I have just checked. There a pipes from both sides. Thank you for that.
    Cheers
    Ian
  10. wecamp
    wecamp Member
    152
    Sep 28, 2006
    Grosse Pointe Park, Michigan
    I had a 2002 Chevy Trailblazer and still own a 2004 Trailblazer. It seemed like they all had trailering packages that included both coolers like you found. I can't imagine GM not including the trailering package on the Bravada. Do you have a factory installed hitch and 7 pin connector?
  11. terry1419
    669
    82
    Mar 6, 2016
    Streator, IL
    Just make sure that the other lines you are looking at are not for the AC condenser which is in front of the radiator.
  12. Snow
    10,957
    1,618
    That would be a transmission cooler not an oil cooler. . Oil cooler will be a small aux. type rad sitting in front of the ac condenser, not to be confused with the aux tranny cooler which will also be mounted infront of the condenser. .
  13. Ian1357
    Ian1357 Member
    45
    Jan 4, 2017
    Hii WWecamp
    Yes I the seven pin connection and the hitch.
