Eternabond width
Discussion in 'Roof/Floor Repair & Maintenance' started by GatorChamp44, Dec 3, 2019.
  1. GatorChamp44
    GatorChamp44 Active Member
    152
    40
    Mar 16, 2017
    I want to seal my alumatite roof center seam and replace my ac gasket (Coleman mach). I am planning on running eternabond tape over the center seam. Wondering if I should go with 4 inch or 6 inch width. Anyone have any experience here? Also, any special prep needed other than simple cleaning?
  2. TRR
    TRR Active Member
    453
    224
    Nov 3, 2014
    Alabama USA
    Are you removing the metal trim on the seam and replacing it with tape, or do you plan to reinstall the metal trim over the tape?
    When I replaced my a/c gasket I used eternabond tape around the a/c opening but not the center seam. I put back the metal trim with white butyl putty under it to seal it. No leaks in 4 years.
  3. GreyFox
    GreyFox Well-Known Member
    2,362
    1,207
    Oct 10, 2018
    S Ontario
    Your Tacoma doesn't have an AlumiTite roof but rather a conventional aluminum skin roof with a single centre seam. I personally wouldn't use Eternabond tape because no matter how careful you are laying it down it still won't look very good. On a travel trailer where the tape can't be seen, sure - but on a popup I'd reinstall the trim covering that seam and use lap sealant to seal it. Don't also forget to seal each of the 4 roof corners as well.
  4. GatorChamp44
    152
    40
    Mar 16, 2017
    Thanks for the reply. What would I search for on Amazon or colemanpopupparts?
  5. GreyFox
    2,362
    1,207
    Oct 10, 2018
    S Ontario
    Part numbers for your 2003 Tacoma are available in this parts book ...
    https://cdn.shopify.com/s/files/1/0273/4347/files/2003_coleman_destiny.pdf?16695232820753828628
    Unfortunately the centre seam (4752-02791) is no longer available from colemanpopupparts so hopefully your original can still be used. Some prefer white self leveling Dicor lap sealant but when I sealed the centre seam on my 2003 a few years ago I used non sag Geocel Proflex lap sealant because it's offered in clear which doesn't show a sloppy application as much as does white. ;)
