Everyone needs a trip to the CAT scale...wow
Discussion in 'Tow Vehicles, Hitch & Towing' started by Renee Wymer, Aug 31, 2020.
  1. RockyRoo
    6,618
    244
    Jun 8, 2012
    Absolutely NOT true. Although they may be unsprung weight your tires and rims each have their own “payload” capacity and with the wrong equipment can in fact be the weakest link in your payload rating, so yes they absolutely can and DO affect your payload rating. Now, this is likely more significant in trucks rather than cars, but it still matters.
    Rusty2192 likes this.
  2. zak99b5
    zak99b5 Active Member
    234
    152
    Feb 21, 2019
    Um, I didn't say they don't affect payload capacity, I said the weight of your tires and rims don't count against your payload. You wouldn't subtract 100# from your truck's payload because your fancy new rims and tires weigh 100# more than the stockers (assuming same or higher load rating for new rims & tires).
    Sean W likes this.
  3. tzmartin
    tzmartin Well-Known Member Diamond Supporting Member
    1,216
    575
    Sep 9, 2015
    Clayton, Georgia
    Thank you for the reminder to get a real world weight for your popup!
  4. Rusty2192
    Rusty2192 Well-Known Member
    1,035
    460
    Jul 30, 2014
    Kentucky
    Again, not true. Payload is just the term for the difference between GVWR and the curb weight of the vehicle. Heavier wheels and tires means a higher curb weight and less payload. Sprung or not, it’s still weight that you have to move, control, and most importantly, stop. GVWR is the important number. Payload is just an easy reference.
  5. jeepster04
    jeepster04 Member
    97
    44
    Nov 23, 2010
    Went to the scales again on the way to the campground. Vehicle and camper were packed full but it was just me in the vehicle. Water tank and water heater were full, propane tank was full, single battery on the tongue. I do wish I could've packed the Jeep, weighed it, then hooked up the trailer and weighed it so I would know the tongue weight. Maybe I'll make the little setup with a board and use a scale, but I dont really care THAT much.
    Steer Axle: 2160 lb
    Drive Axle: 3300 lb
    Trailer Axle: 2580 lb
    Total 8040 lb
    GVWR is 5600 lb so I'm good there but I had the rear axle overloaded by 150 lb. Not really concerned about that...
    I did stop at the scale on the way home but it wanted $12 again instead of the $2.50 to reweigh, so I didnt weigh it. Thought I would see how much it weighed without any water in the tanks n such. I guess its $12 the first time, $2.50 to reweigh, then $12 if you go back again.
    My Jeep is fairly short at 104" and it just barely worked on the scales.
    Ductape likes this.
  6. Rusty2192
    1,035
    460
    Jul 30, 2014
    Kentucky
    I think the reweigh price is good for 24 hours from the first weigh. Then you can reweigh as many times as you want in that period. I did it 3 times in a row when I went. 12/2.50/2.50.
  7. stierheim
    stierheim New Member
    29
    Apr 22, 2013
    Because that is an axle manufacturer rating, it is not the GAWR on the VIN decal assigned by the vehicle/RV manufacturer. GAWR is measured at the tire imprints on the road, not the weight the axle is carrying exclusive of axle, tire, and wheel weight.
    Sean W likes this.
  8. Sean W
    Sean W Member
    33
    Aug 19, 2018
    Understood. I guess I was trying to refer to the actual weight capacity of the trailer itself, thinking that he didn’t know the weight capacity of the trailer. Looking back at the original post, it was TV weight ratings that were in discussion, not the trailer’s. I think I got confused with another question/post where they didn’t know the rating of their trailer.
    Much appreciate the clarification. I know that I can count on the folks on here for sound advice.
  9. Snow
    11,027
    1,672
    Water weighs 8lbs per gallon.. So multiply that by the size (in gallons) of your water tank, then again for your water heater (probably 6 gal.) and add the water tank weight and the heater weight together to get you total water weight..
  10. jeepster04
    jeepster04 Member
    97
    44
    Nov 23, 2010
    Very true but maybe I should've clarified. The water heater adds tongue weight since its right in the front of the camper and the rear water tank is almost right over the rear axle but is mostly behind it, so it lowers tongue weight when full. I was wanting to see how it affected the weight on the vehicle.
  11. Anthony Hitchings
    1,631
    868
    Mar 2, 2019
    y'all making this too complex - don't get your max weight so close to the allowable that you are arguing over wheels and rims
    xxxapache, Sjm9911, JimmyM and 2 others like this.
  12. tiltshift
    tiltshift Member
    52
    50
    Jun 23, 2019
    Paisley, Ontario
    This thread got me thinking, and on our way back out from our last trip of the year, I stopped in at the scrap metal yard close to our house. Drove over the weigh scale with the camper and TV loaded to the gills. The weigh scale operator came out and asked me if I was going to scrap the trailer! Said no, and she printed out a weight ticket for me free of charge for the Subaru and the trailer combined and separated.
    If anyone is interested:
    2010 Subaru Outback 2.5i-4040 lbs
    2008 Starcraft 2106-1820 lbs
    Note that the vehicle weight included a full tank of gas and all our camping gear, and me(160 lbs).
    Note that the trailer weight included some camping gear, in addition since I bought the trailer I've added a beefier axle, upgraded from 13" to 14" wheels, and electric brakes
    Good to know I'm under the GVWR(4585 lbs), GCWR(7285 lbs), and towing weight(2000 lbs with 10% on the hitch).
    Hope others follow the lead of the OP.
  13. Fish N Farm
    Fish N Farm Active Member
    117
    86
    Aug 4, 2020
    Pearland Tx
    It is easier to weigh if you can find a scale with one long platform or one with a single short platform close to your house. . Back in the day even the state weigh stations only had a single long platform. Pull the steering axle on they printed that on the scale ticket then pull the drive axle on they weight that then the trailer. Pay the man and go. Simple math gives you what each axle weighs. You would need to dolly down the tongue jack to get that weight but not a major un hook. It doesn't have to be a public scale there are tons of places that weigh trucks in and out. I don't recommend a metal scrap because of possible tire damage.
  14. tiltshift
    tiltshift Member
    52
    50
    Jun 23, 2019
    Paisley, Ontario
    I was a little concerned bout tire damage at the scrap yard, but not concerned too much bout flouting scrapyard etiquette . Country scrapyard on a Wednesday afternoon doesn’t get busy. No line, no hurry, and much easier for me to just unhook and weigh separately. Only took 2 minutes.
  15. inthedirt
    inthedirt Active Member
    972
    227
    Aug 28, 2012
    SW Montana
    I've got a rock yard near me that has a 24hr scale, unattended and free. My TV is a Ford Excursion 4wd/V10 and weighs in 8200 lbs with me and a full 44gal tank. Took my new-front deck toyhauler out this summer, fully loaded, and stopped at the scales to see how heavy I was. With 3 dirt bikes, my Polaris 500 ATV, a kayak, paddle board, full tanks, and food for a week....I totaled 16,300 lbs combined.
    On Tuesday, I had to haul my daughter's car home for repairs and purchased a new trailer to haul it on. Curious, I swung by the scales again with the 24ft trailer, her Hyundai Sante Fe, and 25 bags (40 lbs each) of wood pellets. With 1/4 tank of fuel, that combined load totaled 14,600 lbs. Without the scales nearby, I wouldn't have imagined that the loads weighed this much. This just underscores the importance of having a decent vehicle to tow with. Sure, I've towed with minivans and small SUVs when it was just a little Pup or small flatbed garden trailer. But once you get up there in trailer size/weight, you need something a little more stout.
  16. BillyMc
    BillyMc Well-Known Member
    1,712
    1,016
    Mar 25, 2018
    Wow, that sounds heavy, I could have sworn the curb weight maxed at around 7k for those. My brothers 4X4 Expedition is just under 5k.
  17. JimmyM
    JimmyM Well-Known Member Gold Supporting Member
    2,957
    930
    Jun 5, 2014
    Franklin, MA
    I love the Excursion. Love it. Want one super bad. Massive 3 row SUV that can tow 11,000#
  18. inthedirt
    972
    227
    Aug 28, 2012
    SW Montana
    It's for sale.......
  19. JimmyM
    2,957
    930
    Jun 5, 2014
    Franklin, MA
    Oooof Montana. That would be a hike. But tempting.
  20. Fish N Farm
    117
    86
    Aug 4, 2020
    Pearland Tx
    The GVWR on the things that RV's pull is to collect road tax or lic. fee's. GVWR is for the safety aspect and on bigger rigs bridge weights. What a vehicle can weigh crossing a bridge is a formula of axle weight axle spacing on tandem axles. Have you noticed trucks with a set of wheels off the ground going down the road? They serve 2 purposes. 1 actually hold up the weight when they are loaded and 2 they can drop them down to make it legal for them to cross certain load zone bridges. I have seen rock hauling dump trucks in the OK state pulling an empty boat trailer. Of coarse I asked them wtf. The answer was It makes the axles far enough apart to be legal. I don't know if the OK state still allows that but how dumb can you get? But, the AMERICAN TRUCKER is the last of the Great American Cowboy. They will figure it out. They can't buy a new $150,000 truck every time a suit want's to see his name in print. They are not risk takers. I will bet 98% of big truck accidents are caused by four wheelers and rookies driving too large of things that they have no training doing.
