Dana Swanson
New Member
- Jul 12, 2021
- 6
What size extension cord do I need to plug up my popup at home?
A/c and lights...and what do you hope to run while its plugged in?
A/c and lights
An ac will run , but that will be about it. You might get ac and lights on a dedicated 15 amp outlet with leds. So that means nothing else in the house on it. Better would be a 20 amp deticated outlet, but once again ac and lights or no ac and fridge. They asked about the distance, because that will determan the guage of the cord.
Depends on the draw size and age of the unit. Most will run fine , if your just running one. As i said 20 amp outlet is better. I wouldn't run anything else but the ac on a 15 amp. You are corect, a underpowered ac can cause the compresser to get damaged.I popped the cover off my A/C and read the label on it. 15AMP to Run, but up to 20 to Start. Just because you can get it to come on and things spin doesn't mean your not doing harm and all is well.
I had some long stuff typed out, but your right. If you dont know and have to ask , then a 20 amp outlet with appropriate extension cord ( 12/2 ) or better is probably the only way to run the ac and only the ac. There are exceptions, and if you are not comfortable or dont know them then dont use anything but the aformentioned. Ok see i agreed. I'm stubborn and don't do that often.I had to correct my post above because I wrote 15amp breakers in my home when I meant 20 amps.
So I have 20 amp breakers, 20 amp rated wire but 15 amp plugs as per this photo I just took with an outlet cover off. I even have some much nicer outlets that I changed out that are smart outlets and even decorative "rectangle" style that are all the same as this one, 15 amps:
Will my AC run off this? You bet it will. Might I damage the A/C? Depends on its current draw/needs. Will I be doing damage to my outlet by overdriving it? Most certainly. I will weaken the components making their rating even lower and it will get hot because I am pulling too much power. The longer I do it the worse it will be for it.
If you want to use a 20 amp extension cord it will be at least 12 gauge wire per strand inside and have the sideways plug for a 20amp outlet.
I know everyone is just trying to help but I don't want the OP to find out the hard way that just because it hooks up doesnt mean you should do it.
