Exterior face lift
Discussion in 'Camper Restoration Projects' started by Kim C, Aug 8, 2019.
  1. Kim C
    Kim C New Member
    Jun 20, 2019
    I am planning to paint the exterior of my pup this weekend. Decals are all removed and the box is clean. I have the Zinsser Oil Base Exterior primer that I plan to roll on. What finishing paint is recommended? I am assuming oil base as well? Its for a 1998 Dutchman Duck and I believe it is a fibreglass skin and not smooth.
    Thanks All!
  2. bheff
    bheff Well-Known Member
    1,504
    909
    Feb 24, 2011
    NW Arkansas
    I'm not positive but I have built/rebuilt several boats. I have used Rustoleum boat paint with great success. Look up the "roll and tip" method. I could create a super smooth mirror like finish that rivaled professionally sprayed paint jobs. It is cheap and easily resourced because Lowes sells it.
  3. Banana Pancake
    Banana Pancake New Member
    Nov 18, 2019
    What did you do to remove old paint and decals? We are wanting to do the same but are unsure of the best way to prep the surface.
  4. GrueMaster
    GrueMaster Active Member
    184
    60
    May 22, 2013
    Saint Helens, Oregon
    Easiest way to remove the decals is with a heat gun, at least on Coleman PUs. It softens the glue enough to make them peel off easily.
    akriot likes this.
  5. Tom & Fran
    Tom & Fran New Member
    Apr 25, 2017
    Wildwood, Florida
    Once
    you remove the decades from your PU and repaint. How do you get new decals? I have a Coleman and there no longer producing PU's .
  6. Tom Jordan
    Tom Jordan Active Member
    108
    56
    Jun 3, 2019
    ArkLaTex
    If you can’t find a seller on Amazon, EBay, Etsy, etc., ask around in your local crafting community. Those vinyl cutters are pretty common now. So if you can provide a graphic file, they can probably cut the smaller decals for you to be glued on.
  7. jon davenport
    jon davenport Member
    40
    55
    Aug 22, 2019
    Kansas
    Hello there! reading your post about restoring your PUP. There are a bunch of places to find vinyl decals now. it takes a bit of foot work to look through the web. Here is a guy I found a couple years ago, he has done 4 different jobs for me and all have turned out well. Best of luck , and looking forward to your pics :) https://www.facebook.com/BMACKDECALS/
