Extra Water Line to pump?
Discussion in 'Mystery Parts' started by Jhunt012, Jan 21, 2016.
  1. Jhunt012
    Jhunt012 Member
    53
    Aug 27, 2015
    I have a 2006 Fleetwood Cheyenne. When crawling around underneath to remove the drain plug on my water storage tank I noticed a clear hose with a shut off valve and a male ribbed brass fitting. It is under the camper and the other end goes to my electric water pump. Basically two hoses go to my pump - one from the water storage tank and another that Seems to be set up to pump from somewhere else. Any ideas what this is for? Thanks!!
  2. Raycfe
    16,486
    2,263
    Low point drain..
  3. speckhunter80
    4,782
    63
    Jul 26, 2012
    Shell Rock Landing, Hubert NC
    Possibly for sucking up antifreeze out of a bottle
  4. Jhunt012
    Jhunt012 Member
    53
    Aug 27, 2015
    To drain water out of pump?
  5. Customer
    Customer Well-Known Member
    2,435
    244
    Jun 5, 2014
    Probably a winterizing kit to pump antifreeze.
  6. mv520
    mv520 Member
    587
    24
    May 2, 2010
    And the faucet (by opening the faucet valves inside the PUP to let air into the line there)
    To make sure we're talking about the same thing, on my 06 Cheyenne, from the factory it has a line that goes from the output of the pump, back down under the floor, heads forward, and then right below the sink it has a T. One leg goes up through the floor to the faucet, and the other leg goes to a short 2" stub of a hose and a small bras valve. So opening the valve is a "low point" drain, but I personally wouldn't count on it by itself to get water out of the nooks and crannies of both the faucet and the pump itself for winterizing purposes. Apparently Fleetwood did since they went to the effort to install it, but it seems marginal to me.
  7. Nandy
    Nandy Active Member
    2,255
    Mar 29, 2010
    Pictures will help us help you.
  8. Customer
    2,435
    244
    Jun 5, 2014
    The OP appears to indicate that there are two lines on the supply side of the pump, so it would not be a drain.
  9. Snow
    10,546
    1,322
    Have to agree it sounds like a winterizing kit has been installed to allow the pumping of antifreeze ... Could also have been used for an aux. water tank as well ..
  10. kitphantom
    12,068
    1,109
    Sounds like the hose on ours meant to draw antifreeze directly from the bottle. works great. (The TT is the first camper we've had with a water system, so we had to learn how to winterize. We use the blow-out/antifreeze combination, and use less than a gallon of antifreeze.)
    The low point drains on ours are just that, at the low point, which is not where our water pump is.
