Fabric Repair
Discussion in 'Canvas / Awnings / Add a Rooms / Tarps / Tents' started by Daniel coln, Oct 3, 2021.
  1. Daniel coln
    Daniel coln New Member
    Oct 3, 2021
    Picked up this "85 Coleman Sun Valley recently. It's in pretty good shape. I replaced the tires and installed an electric water pump. I have an issue with some fabric damage that I hope someone can recommend a method to repair short of replacing the entire panel.
    Dan
  2. Arruba
    Arruba Well-Known Member Gold Supporting Member
    690
    359
    Nov 28, 2014
    Central Oregon
    Kellita Camper likes this.
  3. jmkay1
    6,968
    4,015
    You could find patch kits on Amazon as well. Tear aid is a great glue to help attach the patch. Cut the patch larger then you need especially if you find the canvas thin.
  4. kitphantom
    13,218
    2,325
    If it is the Evolution fabric, it is pretty much at the end of life, if not beyond. (I’m out camping and the obits won’t load) You can try sewing patches, then use seam sealer, or Tearaid tape (there is a fAbric version, and a vinyl one, found on Amazon and elsewhere)
    It is feels papery, it probably is Evolution. We had it on our first, 1984, pup. I patched it until it didn’t have enough integrity to hold a patch: sticking my finger through the fabric was one clue it was done.
    Kellita Camper and Sjm9911 like this.
  5. michaeltdyer
    michaeltdyer Active Member
    179
    29
    Nov 26, 2012
    Denver Colorado
  6. UpNorth-John
    UpNorth-John Member
    96
    28
    Sep 4, 2010
    I like the Tear-Aid Fabric (will have to remember that). A couple other suggestions: you could try sail mending tape (West Marine or any other large boating equipment supplier) or take a look at Sail-rite https://www.sailrite.com/Fabrics. They have a product called Phifertex that looks similar. If it's not a good match, they may be able to suggest something. The Sail-rite folks are all about DIY projects for boating, camping, canvas and upholstery.
    Good luck with your project.
  7. pastorkeith
    pastorkeith New Member
    Apr 19, 2017
    Ashland KY
    I have an 86 Coleman and that is the evolution fabric. I have never had to patch anything that big, but seam grip sticks to the fabric well. It is available on Amazon or at camping stores. I would try glueing on a patch of fabric like canvas.
  8. Bullfrog Bheer
    Bullfrog Bheer Well-Known Member
    2,922
    78
    Feb 19, 2010
    Central Wisconsin
    That is definitely Evolution III. We have the same on our 1990 Coleman. Our canvas is on it's last season. We have the new one on order. We have had some luck getting clear Gorilla Tape to stick to it. Doesn't look the best, but works in a pinch.
