Fantastic Fan interference
Discussion in 'A-Frame PopUps' started by Anthony Hitchings, Mar 21, 2019.
  1. Anthony Hitchings
    1,277
    595
    Mar 2, 2019
    so I installed the Fantastic Fan today, and as I was doing so, with the roof now closed (for easier access to the screws in the flange) - it seemed that the vent opening knob projects down too far, so it and the other knobs and the fuse cap were all removed in order for me to proceed.
    Anyone else had this problem?
  2. joet
    4,984
    1,065
    Something wrong as on mine I don't have anything protruding below the ceiling.
  3. BikeNFish
    BikeNFish Well-Known Member
    3,444
    2,326
    Apr 24, 2017
    Maplewood, MN
    Doesn't sound right to me either. Do you have a post installation pic?
  4. shuang2
    shuang2 Well-Known Member
    1,187
    98
    Apr 20, 2010
    Our Chalet Fantastic ceiling fan has similar problem. I always need to push the top panel a bit, while break down the roof maybe cut off the knob.
  5. jeicher
    jeicher Member
    88
    65
    Sep 17, 2011
    Had the same problem installing fan in my Alite a couple of years back. Purchased a standard Fantastic Fan instead of the special OEM version. I removed the fuse, cut off & slotted the switch spindle. Added a fan forward/reverse switch and fuse near the inverter. If I needed to change speed I could use the screwdriver slot I added to the switch spindle. It worked great and wasn't that much extra work since I had to run a 12V line to the fan anyway.
    [​IMG] [​IMG]
  6. eoleson1
    eoleson1 Well-Known Member
    2,856
    1,142
    Jul 5, 2011
    Macomb County Michigan
  7. Anthony Hitchings
    1,277
    595
    Mar 2, 2019
    Thanks, jeicher - I will likely take the same path as you did; but without the reverse (which I can add later). The fan seems less effective in reverse (I did a bench test). It was interesting to see that the fan uses dropping resistors to control speeds. Nothing fancy. Which means we can add a reverse later.
    Actually, if I add the remote on-off switch it can also be reversing if I use a DP-DT switch, not any extra trouble for the installation.
  8. jeicher
    jeicher Member
    88
    65
    Sep 17, 2011
    I believe I used a DPDT switch with a center off position.
  9. Anthony Hitchings
    1,277
    595
    Mar 2, 2019
    I bypassed the fan’s fuse and removed the fuseholder, because my fan is on a dedicated fused branch circuit
