Fender flare river with adhesive mount
Discussion in 'Mystery Parts' started by Robert Rosin, Aug 2, 2020.
  1. Robert Rosin
    Robert Rosin New Member
    Aug 2, 2020
    Tried everything to find this, google image search etc...
    The body of my pop up has three rivet inserts and the below part attaches to the fiberglass fender flare of my Starcraft Gemini
  2. WrkrBee
    WrkrBee Un-Supported Member
    6,569
    3,461
    Another reason to have a 3D printer. I need to get one.
    Steveo4090 likes this.
  3. Steveo4090
    Steveo4090 Well-Known Member
    782
    736
    Jun 26, 2020
    Lancaster PA
    So you need the tan part or new poppits to secure them? Or both?
    What's the front of it look like?
  4. Robert Rosin
    Aug 2, 2020
    Howdy Steve-
    I need three rivets and at least one semi circle.
    the rivets pop through the semi circle mount which is affixed to the inside of the fender. Then the rivets are inserted into the wall of the pop up
  5. Anthony Hitchings
    3,155
    1,880
    Mar 2, 2019
    Oakland, California
    you could likely get the "rivets" at an auto parts store.
  6. Steveo4090
    782
    736
    Jun 26, 2020
    Lancaster PA
    Try searching "retainer clips for cars" and maybe put in the length of yours. Should be able to find something close that'll work.
    You're probably going to need to make the semi circle things. Might be able to find plastic washers at the hardware store and epoxy them together and trim the one side down. Probably your only option is to use your imagination like a lot of fixes for old pups. Good luck!
  7. neighbormike
    3,556
    4,313
    Oct 6, 2012
    WI
    Agreed... just looks like a body panel retainer - lots of different styles and sizes... bring one to O’Reilly’s - they can probably match it to something that’d work.
  8. xxxapache
    4,117
    2,426
    Any decent auto parts store will have push rivets. In addition, you can get them at Lowe's. For the semi circle part, look for "fender washers". You can find them in both nylon and steel. Trim them to the shape of the originals.
    I recent needed some fender washers in that exact shape. I used steel ones. I clamped them in a vice and used an oscillating tool to cut them.
