Filling up at the gas station
Discussion in 'First Time & New Camper Owners' started by robsonj, Jan 16, 2013.
  1. Bullfrog Bheer
    Bullfrog Bheer Active Member
    2,870
    Feb 19, 2010
    Central Wisconsin
    This is an interesting question. You don't see too many here that haven't been asked a hundred times before.
  2. Snow
    10,186
    1,089
    I should also have added, I use the outside lanes more, due to the height of the TT (plus the a/c unit) ..
  3. silvermickey2002
    4,677
    478
    Sep 11, 2008
    Morris County, NJ
    We have only found one gas station in Arvada, CO (Suncor Energy- Shell station) on Ward Rd and West 64th that it did not matter what entrance you came in you would be at the wrong angle at the pump. It was just a small place. If I did decide to fill up we would be blocking the parking lot. We ended up just pulling on thru and went to another station down the road.
  4. BuxCamper
    BuxCamper Member
    318
    Mar 29, 2003
    Bucks County, PA
    I've used the camper pumps at Flying J, convenient and you know you won't be making things difficult for non-RVers. Otherwise I scope out the place to see how 25 feet of HTT will fit. Usually use the outside lane pumps.
    Sent from my Xoom using Tapatalk HD
  5. Travelhoveler
    Travelhoveler New Member
    2,337
    Mar 8, 2011
    The RV pumps are the Flying J Travel Centers, not the regular Pilot stations. You can get a free app to locate all the stations and tell what services they have.
    The Flying J Travel Centers also do propane refills (discount with your FJ RV card) and have dump stations, too.
  6. RobertGreenlee
    RobertGreenlee Member
    318
    Mar 28, 2012
    Here is another question. When towing with the fridge on propane I stop to shut off the propane before going into the gas station but my fridge has a electronic ignition so there is a chance it could spark while there. There is also no way to get to the fridge controls with the pup closed.I do feel better that my trucks filler is on the curb side and the fridge is on the other so I will always get a outside lane pump to keep the fridge as far away from any fumes as possible.I guess I could add a battery cutoff switch like many of you have done to kill the fridge totally while getting gas.
    Sent from my SGH-i917 using Board Express
  7. Travelhoveler
    2,337
    Mar 8, 2011
    Can't you tow on 12 volt, and use the propane once you get to the campsite?
  8. Snow
    10,186
    1,089
    Re: RE: Filling up at the gas station
    Our TT has the same sort of thing, think all TT, MoHo's and that have a re-ignighter on the fridges... Many of these are only a two way fridge (propane and 120vac) so folks with those types of fridges generally just leave them turned on and running with the propane.. I wouldn't worry about it to much, very low chance that the fumes from around a gas pump while pumping gas could get high enough up to the level of the fridges burner box, let alone be at the right combustable mixture..
  9. CamperJenn
    CamperJenn Member
    435
    Dec 18, 2012
    Ontario, Canada
    I try to use the outer pumps, and pull up far enough that someone could get in behind me for gas.... Not always possible at smaller stations... But I try.
    I do get the stink eye when I take up two pumps... What do you want me to do?? I need some too.
    I try to fill quickly and go.
    Luckily I drive a ford escape... 52 litre tank doesn't take too long to fill.
    Sent from my HTC Ruby using Tapatalk 2
  10. warwgn3
    warwgn3 Car Shows are 2nd only to Camping!
    246
    Feb 21, 2010
    I use whatever pump is available.
    I also use a Fleet discount card that gets me $0.04 per Liter off the pump price at any Esso, Exxon, Mobil station in Canada and the US.
  11. rabird
    6,718
    307
    TX
  12. vagov
    vagov Well-Known Member
    4,212
    382
    Aug 13, 2012
    Pittsburgh, Pa
    thats why i usually try taking the outside lanes because it seems like theres always someone who dosent take your turning radius into mind and winds up boxing you in [:(!]
  13. BigBaron
    4,583
    Jun 21, 2012
    Korea is different. We just pull in. It's fun to watch everyone stare because trailers aren't that common here. [LOL]
  14. BarbaraFaith
    BarbaraFaith New Member
    1,447
    Oct 15, 2011
    I guess I've never thought about this, because, up to now, we have just taken trips 1 hr to 3 hrs from home. I always gas up before we go, and gas up the night before we leave.
    However, we may make a potty/snack stop at a gas station. Since DH has mobility issues, and walks with a cane, I will drop him off at the door, and then park the TV/PUP in the outer parking lot, walk in to the station to do what I have to do, and then walk back to the TV/PUP and swing around and pick him up.
  15. FarmerDave
    FarmerDave Active Member
    653
    46
    Jun 15, 2012
    Nova Scotia
    Regular fuel pumps, I drive a diesel so most gas stations have limited diesel pumps to start with so that complicates just pulling in since "one size(pump) doesn't fit all) I try not to block any other pumps.
    I more so worry about pulling AWAY from the pump than getting to it, especially pumps that are perpendicular to the road versus parallel. Inevitably some dummy will block you in if you otherwise don't plan ahead.
  16. NJGuy
    NJGuy Active Member
    2,353
    Apr 20, 2010
    One of my least favorite activities. Last time refueling in Las Vegas (also known as Lost Wages), vehicles entering a shopping mall narrowed my maneuverability to exit the station and turn back onto the road. Accordingly, we try to stop at modern truck stops that provide more space for TV and PUP, even if gas is more expensive.
  17. fritz_monroe
    fritz_monroe New Member
    1,307
    Jan 31, 2006
    Refilling while hooked up is stressful to me until I get to the station. Once I see that I have plenty of room to maneuver, I'm fine.
    Sent from my YP-G70 using Tapatalk 2
  18. hotrodcamper
    hotrodcamper Member
    972
    Nov 3, 2012
    I try not to block any pumps,but like other people have said, sometimes you just can't help it. With that said,I try to fill up and move out of they way if people are waiting. Sometimes you just have no choice but to make others wait.
  19. BuxCamper
    BuxCamper Member
    318
    Mar 29, 2003
    Bucks County, PA
  20. Unstable_Tripod
    14,279
    35
    May 20, 2008
    Seattle, Washington
    These people failed to comply with the rule that you extinguish all sources of flame (including propane device pilot lights or fridge flames) before entering the gas station. Their experience is a great illustration of the reason for this rule.
