First pop-up, a 1996 Starcraft Starlounge
Discussion in 'Introduce Yourself' started by Gafrus, Aug 30, 2019.
  1. Gafrus
    Gafrus New Member
    Aug 13, 2019
    Hi!
    I've never had a pop-up before but just bought a 1996 Starcraft Starlounge. Didn't intend to get one that's so huge but that's what I found! I'm in Minnesota and plan on using it for some grouse hunting this fall. It's in pretty good shape for how old it is but I'm still trying to figure everything out. So far I've tested out the water pump, water heater, and lights and that all works. The sellers said they have never used the furnace before and that is what I'm going to be looking into this weekend. I immediately noticed the reset switch on the internal fuse was broken so I replaced that but there is still no fan coming on and it's not trying to light. I'll test with a multimeter this weekend during my 2nd practice setup and will probably be back with questions!
  2. neighbormike
    2,261
    1,636
    Oct 6, 2012
    WI
    Welcome from Wisconsin and congratulations on the new pup! I am assuming you are plugged in to 110... first things I would check: make sure your battert is hooked up properly, safety switch on the galley, thermostat. You can try jumping the thermostat to rule that out.
    nineoaks2004 likes this.
  3. nineoaks2004
    7,162
    2,960
    Dukes, Fl
    Welcome from N/W Fl Panhandle. Congrats on the NTU PUP. Just take the time to check everything out and learn how to work them. Good Luck and Happy Camping
    neighbormike likes this.
  4. joet
    4,596
    878
    Welcome from the West Virginia mountains
  5. fourhallatts
    fourhallatts Active Member
    919
    248
    Jul 18, 2015
    North Syracuse, New York
    Welcome to the portal from Central NY.
  6. Raycfe
    15,102
    1,372
  7. WrkrBee
    WrkrBee Well-Known Member
    2,343
    890
    Welcome to the Portal from South Carolina.
  8. Artist60164
    Artist60164 Active Member
    148
    38
    Aug 9, 2019
    The Windy City
    Do you have inside pictures? This one sounds like a Cruise Ship.
  9. Gafrus
    Gafrus New Member
    Aug 13, 2019
    Here's some interior pictures from the sellers listing. I won't have quite so many pillows usually...
  10. bobinfleet
    bobinfleet Active Member
    398
    158
    Sep 2, 2011
    Hampshire UK
    Hello and welcome from Hampshire UK[GBR] good luck with the pup
  11. megcabra
    megcabra Well-Known Member
    1,850
    464
    Aug 12, 2015
    Chapel Hill, North Carolina
    Welcome and greetings from North Carolina to the exciting world of Pop-Up camping!
  12. kcsa75
    kcsa75 Well-Known Member
    2,852
    1,254
    Sep 9, 2013
    Kansas City
    Congratulations on the NTU Pup and Welcome to the forum from Midway USA.
  13. Shaman1
    Shaman1 Well-Known Member
    2,234
    504
    May 13, 2011
    Oklahoma City, Oklahoma
    Welcome from Oklahoma.
