First time p-up owner what the f are these poles for
Discussion in 'First Time & New Camper Owners' started by Mkblair009, May 16, 2016.
  1. Mkblair009
    Mkblair009 New Member
    May 15, 2016
    Under the mattress of my 98 Coleman are these hooklike poles what is their purpose in life? Why do they exist?
  2. woodworkerfella
    woodworkerfella Member
    50
    Feb 15, 2015
    Fayetteville, NC
    They prop up your bed canvas. Put the tip down at the end of the bed into the hole in the bar holding up the canvas. The hook end connects into the camper ceiling. Insert it into the bracket with the hole and the two depressable pins prevent it from falling out.
  3. Novarich
    Novarich Active Member
    360
    34
    Dec 8, 2014
    Without a pic im going to guess your shepherds hooks for your bunks. Straight end has a pin that goes in the top center of the hoops at the outboard ends of your bunks and the curved end goes up into the socket in front center of bunk in the roof.
  4. Snow
    10,174
    1,081
    x2 need a pic to be sure, could be safety support bars for the lift posts ... could be a lot of things...
  5. Lugnutz
    Lugnutz Member
    96
    Apr 11, 2015
    Shepard hooks keep canvas over sleeper from saggin. also in heavy wind keeps loops from swing back int beds. The old ones had a hard rubber tip that goes into a hole in the loop, newer models have a "C" looking attachment at end. the other end has an adj, usually use the longest setting. an that hooks to a slot at end of of bunk. There is one at each end of bunk.If they break you can order them, BTW to dislodge broke one run dowl rod down the back and knock thm out.
  6. jnc
    3,928
    1,173
    Oct 1, 2014
    South Central New Hampshire
    I have one of those hooks for the galley window that bumps out a little
  7. mschepac
    mschepac South Jersey
    1,386
    Apr 22, 2008
    South Jersey
    Are these the hooks that you are asking about? If so, here is an example...
  8. Mkblair009
    May 15, 2016
    Yes thanks everyone seems to be right here
  9. Milktrk
    Milktrk New Member
    331
    Apr 17, 2014
    Be careful when you replace the poles under the mattress you can tear the vinyl backing very easily.
    They should be adjusted for the size of the bunk end, if you are having a hard time getting the pole secured to the roof you may have them extended too far and you will have to shorten them.
  10. Laralee
    Laralee New Member
    May 16, 2016
    This made me LOL because I am super new here and to the world of pop ups so I'm glad to see I'm not alone! [LOL]
  11. Lugnutz
    Lugnutz Member
    96
    Apr 11, 2015
    MILKTRK: I place mine on the deck. I am alone and really dont carry much to begin with. I am thinking of getting something smaller .
  12. 91Starcraft
    91Starcraft Member
    141
    Apr 14, 2016
    [​IMG] hope this picture they are to hold the bunkend tops up.
  13. WeRJuliIan
    907
    90
    May 15, 2014
    Sarasota, FL
    Laralee and Mkblair, welcome to the curious world of PUPs where nothing seems obvious unless you've had a PUP or two. There is a learning curve but everyone here was once new and is happy to help with questions. Explore the site and you'll find tons of tips and tricks but most of all, lots of laughter (mostly at ourselves!).
    Happy Camping!
    Jules (The Lady from Little Rock) :)
  14. webhannet
    webhannet Member
    244
    Feb 8, 2016
    Do you really need to use "WHAT THE F" to communicate? This isn't THAT KIND of FORUM.
  15. HappyFamily
    HappyFamily Member
    601
    May 20, 2014
  16. Natureangel
    980
    179
    Feb 28, 2016
    Illinois
    The poles are very handy to place holes in your screens when handled the right (WRONG) way
  17. tfischer
    tfischer Well-Known Member
    3,543
    1,054
    May 21, 2014
    I'm not sure what made me chuckle more... this post, or trying to picture the OP set up the bunks without the poles.
  18. bgbluram
    bgbluram New Member
    57
    May 26, 2016
    Haha, I just acquired my first PUP also, and there were a few things that had be scratching my head. Those poles were one of them.. The other was the plastic clips on top of one of my cabinets (which I found hold the 3-way fridge) and the cabinet with a hinge on it that swings up into a closet. I'm new to these too but I'm having a lot of fun with this thing!
  19. tfischer
    3,543
    1,054
    May 21, 2014
    When I was first considering a PUP I watched a few YouTube videos of how to set one up, because I frankly had no idea. Fortunately my seller also took me through the process, but I was already familiar with it thanks to those videos.
    There will be slight differences with different brands/models but the gist of it is the same.
  20. kcsa75
    kcsa75 Well-Known Member
    3,009
    1,394
    Sep 9, 2013
    Kansas City
    Agreed. [:)C]
