Flagstaff MAC Fuse question
Discussion in 'Wiring' started by Jon McDuffie, May 30, 2020.
  1. Jon McDuffie
    Jon McDuffie New Member
    17
    May 30, 2019
    We recently acquired a 2008 Flagstaff Mac 227. The fourth fuse from the top has blown a couple times. It was a 15 amp. I've replaced it with a 20 amp but as you can see the writing on the left that specifies amp size is very hard to read. Does anyone happen to know what fuse that fourth one from the top is supposed to be? We have a power winch if that makes a difference. Thanks!
  2. rabird
    7,656
    768
    N. TX
  3. Raycfe
    17,460
    3,021
    What doesn't work with the fuse out???
  4. Jon McDuffie
    17
    May 30, 2019
    The only thing I've noticed so far is the power winch is not working. however the battery is powering lights fans etc. So I'm wondering if it's just not charging up enough to power the winch.
  5. Jon McDuffie
    17
    May 30, 2019
    Forgot to mention that the manual for the WFCO converter states that none of the circuits should have greater than a 20 amp fuse.
  6. bheff
    bheff Well-Known Member
    1,504
    928
    Feb 24, 2011
    NW Arkansas
    Your winch should be direct wired to the battery with an inline breaker or fuse.
    Edit: in your pic, circuit 4 almost looks like it says 30 amp. Edit again! Just found a video and it says 20 amp just like Jon mentions.
  7. Jon McDuffie
    17
    May 30, 2019
    Thanks, can you send a link to the video?
  8. Raycfe
    17,460
    3,021
    Things that should be protected by the fuses
    1. Dome lights
    2. Water pump
    3. Water Heater if self lighting
    4. Refrigerator if it works on 12 volts
    5. Ceiling/vent fans
  9. Jon McDuffie
    17
    May 30, 2019
    Just as raw bird mentioned the fuse in question goes to the battery. Given that, does anyone know what size fuse that should be?
  10. Jon McDuffie
    17
    May 30, 2019
    ...rabird
  11. Raycfe
    17,460
    3,021
    no more than 20 amp
  12. Jon McDuffie
    17
    May 30, 2019
    Thanks all for the help. Love this forum!
  13. rabird
    7,656
    768
    N. TX
    see post #2, page ??? 30A, from WFCO's operating manual.
    With a discharged battery, ALL of the 25A rated DC output can go into the battery.
    this manual says max of 25A
    http://wfcoelectronics.com/wp-content/uploads/2015/05/4-3_Operator-Manual.pdf
    Edited to add:
    It is known that the 8700 series WFCO claims a bulk charge voltage of 14.4v and rarely charges at that voltage instead it charges at 13.6v. WFCO is designed to do 4 hrs max @ 14.4v IF the battery is severely discharged. WFCO does not indicate what severely discharged is. but a discharged batt will accept more energy at mid 14v versus 13.6v.
    Jon McDuffie likes this.
  14. Jon McDuffie
    17
    May 30, 2019
    20 vs 30. This is why I am confused. See the pictures with my original post. Everyone I show the picture to says that that 4th circuit looks like it says 30. However check out The very last sentence on this page from my manual. It clearly states 20 is the max. So for now I'm going with a 20. MVIMG_20200531_133311.jpg
  15. rabird
    7,656
    768
    N. TX
    it also states max 30A for AC which means your older model can not have a 30A main breaker back-feeding the buss!
    They obviously changed the manual over time. So keep your 20 and DON"T over-discharge the battery, no worries but poor battery life with a wfco.
