Flex Seal as a roof coating ?
Discussion in 'Roof/Floor Repair & Maintenance' started by markc52003, Apr 17, 2013.
  1. markc52003
    markc52003 New Member
    Mar 17, 2013
    Hi
    Has anyone used or seen someone use Flex Seal (as seen on TV) as a roof coating on an aluminum roof ?
  2. Old_Geezer
    Old_Geezer Well-Known Member
    2,669
    396
    Sep 29, 2009
    Southwest PA
    I have not seen it used on a camper roof, but Phil Swift sure made a nice bass boat out of an S10 pickup on that commercial out of it.
    [LOL] [LOL] [LOL] [LOL] [LOL]
    Seriously, don't waste your money on that crap. Search through the roof thread and do what others have done. Why do you need to coat an aluminum roof anyway? Isn't it the seams and molding caulk joints all you need to worry about?
  3. Raycfe
    17,158
    2,762
    I work part time at a True Value Hardware .......... totally junk will dry out over time. Then you will have a bigger mess.
  4. Starcraft Away
    Starcraft Away New Member
    853
    Feb 10, 2012
    If your looking for a roof coating go with Koop seal or some type of elastomeric seal. Met hey can stand up to uv rays yet still flex in cold weather. It also helps reflect heat off the roof, meaning cooler inside
  5. Old_Geezer
    2,669
    396
    Sep 29, 2009
    Southwest PA
    Junk??????????? Without using that stuff how do you ever build a boat out of a screen door?????????? [LOL] [LOL] [:O]
    And didn't you see the new commercial where the guy with one of those racing boats says " when I get a leak I grab flexseal" [LOL] [LOL] [LOL]
  6. Raycfe
    17,158
    2,762
    I would like to see them go fishing in that boat on fishing opening day this year. [LOL] [LOL] [LOL] They could open the screen door and put their feet on the bottom of the lake. [LOL] [LOL] [LOL] Or look like Aquaman with the boat around waist. [LOL] [LOL] [LOL]
  7. barbjmj
    barbjmj Member
    617
    Aug 28, 2009
    Mid-Willamette Valley, Oregon
    I have an ABS roof with constant cracking year after year. I have used Flex Seal for the past two years. I had to buy the black color for my white roof - even though now they have white color. After the Flex Seal drys (which is pretty quick) I use Kool Seal mostly to get the repairs back to white.
    I used Kool Seal on the roof when we lived in AZ. My experience is both products work well - at least in my use they have performed.
    The bigger problem is the ABS product itself. No easy fix and constant maintenance. Even the RV repair shops won't touch it. If anything drives me from a PUP it will be the constant nagging roof repairs.
  8. markc52003
    Mar 17, 2013
    I've had a chance to see flex seal that has been out in sun light for around 7 months IT DOSN'T WORK !
    Doing some more checking around found a blackjack brand Elastomeric coating ( Ultra Roof 1000 ) at Lowes for $22.98 a gal .
    I saw that a lot of people are using grizzly liner at over $80.00 a gal . WOW
    I'm just looking to coat my aluminum roof to seal 4 or 5 small holes from tree limbs that hit the roof in an ice storm when the past owner had it.
